VGA resistor substitutions? — Parallax Forums
CJCJ Posts: 470
edited 2006-06-06 18:20 in Propeller 1
Would it be possible to use either 220s or 270s in place of the 240s for the VGA interface?
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
    edited 2006-06-06 14:25
    Cj,
    It would probably work just fine, but consider with either one that your going to be about %10 out of spec.
    If your are using 10% tolerance resistors to begin with, you have a potential to be out by as much as 20%
    or right on the money depending on which way they lean. In this situation, I would probably hand pick the
    values so that they are at least within 5% (228 to 252).
    Beau Schwabe
    IC Layout Engineer
  • CJCJ Posts: 470
    edited 2006-06-06 17:01
    built it up on some perfboard with 5% 220s works beautifully with Chip's new high res vga demo
  • Kaos KiddKaos Kidd Posts: 614
    I had nothing in the 210~250 range, so I went and got 10 turn 1K pots, dialed them in to 240 and it's sweet.
    I was playing around with them, and while I was only running the vga_text object, I didn't get noticable change until < 210 or > 270.
    Just tossing my two bits worth into the bit bucket
    KK
