CMOS/TTL Interfacing — Parallax Forums
Timothy D. SwieterTimothy D. Swieter Posts: 1,613
edited 2006-06-06 07:42 in Propeller 1
First let me say, I love the Propeller!!· I have been playing with it for the past week and just love the power it has - I am looking forward to using it in a real project above just experimenting (maybe even for a project at work).
One area that I am having trouble with is the TTL/CMOS interface.· I have read else where in the forum about the 1k resistor between the Propeller input and the TTL devices output - no problem, I have seen this used before.· The problem I am running into is the logic high level of the TTL device is greater then the 3.3V that the Propeller provides.· One device I am working with is the Hitachi HM55B Compass module that Parallax sells.· I believe my problem is with the logic·levels, any advice for interfacing the output of the Propellers to the inputs of the HM55B?· I worked with a coworker on a project a while ago with interfacing 3V CMOS to 12V CMOS, I could dig out that schematic; I don't remember what we did.· I thought I would check with you guys as you often have a quick, simple solution.
I will also be interfacing to the·Hitachi H48C, but have not studied the data sheet to know if I will run into the same problems.
I would recommend that Parallax create a guide (PDF) that explains the CMOS, TTL, and interfacing.· I see this as a possible resource for the many intermediate hobbyists who are going for a BASIC STAMP to the Propeller.
Timothy D. Swieter
www.tdswieter.com
One little spark is all it takes for an idea to explode
    edited 2006-06-05 04:30
    According to the spec's, the HM55B wants to see something like 4V as a logic HIGH.
    You can try something like this simple level shifter below that will give you about
    900mV for a logic LOW and about 4.12V for a logic HIGH.
                                        4.7K
                                     o--/\/\--> +5V
                          D1   D2    |
    0V to 3.3V Input >----|<---|<----o--------> 900mV to 4.12V Output
    ...If you want to use a transistorized Level-Up-Shifter then the attached schematic should work.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/5/2006 4:56:16 AM GMT
    797 x 423 - 70K
  • David BDavid B Posts: 593
    edited 2006-06-05 14:55
    A quick and easy way to do this is to add a 5V 74HCT14 schmidt trigger hex buffer chip to your board. The 3.3V propeller is able to switch its inputs, and you get 0-5V on the outputs. The logic level is inverted, but that can be accounted for in your Spin program. Plus with a single inexpensive part, you get 6 level converters.
    Probably there are other chips that would also work; I used the 74HCT14 because I happened to have a bunch of them lying around my workbench.
    I used the 74HCT14 on my Propeller board to both power and drive the data of my LCD display, and it works great.
    David
    edited 2006-06-05 16:13
    Thanks guys. I will check into both of these options. I like the simplicity of the 74HCT14 - I will have to order these as I am sure I don't have any laying around. I will stop by Radio Shack tonight and grab a few componets to try Bau's sugestions.
    Timothy D. Swieter
    www.tdswieter.com
    edited 2006-06-06 06:57
    You may also want to look at the 74AHC14 as it is slightly faster.
    (7 - 9 nS propagation delay, instead of 15nS for the HCT)
    Don't visit my new website...
  • T ChapT Chap Posts: 4,249
    Not sure about switching times, but I use optocouplers all the time to change 5v to 24v, 24v to 5v etc. Maybe use a 4v Zener to modify the output downwards from 5v if you like the idea. Everything stays non-inverted, but you gotta pull the photo tranny output low with a 10k. Very few parts per channel to build.
