Need help with new SpeakJet
I have attached a pdf of the circuit I am working with at the bottom.
I recently bought the SpeakJet and I am able to get it to work in demo· mode setting the jumpers M0 to V+ and M1 to V+ but when I set M0 to V- and M1 to V+ (Normal mode) the speak jets ready LED is on but when I try to run the example code, it does not do anything. I'm trying to figure out if my custom board design is at fault, or if I am doing something wrong with the serial interface. I have Pin 15 of the stamp going to the SPeakJet's RCX pin and Pin 14 of the stamp going to D2 of the SPeakJet.
Do I need to set the baud rate? Are my serial connections wrong? I am not using the DB9 connector, I want to use the stamp pins of the Homework Board.
Post Edited (SN96) : 6/4/2006 1:32:03 PM GMT
' ========================================================================= ' ' File...... SpeakJet_Demo.BS2 ' Purpose... Serial Control of TIGERBOTICS SpeakJet Board ' Author.... (c) 2004 Parallax, Inc. -- All Rights Reserved ' E-mail.... [url=mailto:support@parallax.com]support@parallax.com[/url] ' Started... ' Updated... 30 JUL 2004 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' Connections: ' ' P15 ----> DB9.2 ' P14 <---- DB9.8 ' Vss ----- DB9.5 ' -----[noparse][[/noparse] Revision History ]------------------------------------------------ ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- Tx PIN 15 ' serial out to SpeakJet Rdy PIN 14 ' Ready in from SpeakJet ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- #SELECT $stamp #CASE BS2, BS2E, BS2PE T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 #ENDSELECT Inverted CON $4000 Baud CON T9600 + Inverted Sync CON $55 ' -----[noparse][[/noparse] SpeakJet Control Codes ]------------------------------------------ PA0 CON 0 ' pauses PA1 CON 1 PA2 CON 2 PA3 CON 3 PA4 CON 4 PA5 CON 5 PA6 CON 6 Fast CON 7 Slow CON 8 Stress CON 14 Relax CON 15 _Wait CON 16 ' note underscore Soft CON 18 Volume CON 20 Speed CON 21 Pitch CON 22 Bend CON 23 PortCtr CON 24 Port CON 25 Repeat CON 26 CallPhr CON 28 GotoPhr CON 29 Delay CON 30 Reset CON 31 IY CON 128 IH CON 129 EY CON 130 EH CON 131 AY CON 132 AX CON 133 UX CON 134 OH CON 135 AW CON 136 OW CON 137 UH CON 138 UW CON 139 MM CON 140 NE CON 141 NO CON 142 NGE CON 143 NGO CON 144 LE CON 145 LO CON 146 WW CON 147 RR CON 148 IYRR CON 149 EYRR CON 150 AXRR CON 151 AWRR CON 152 OWRR CON 153 EYIY CON 154 OHIY CON 155 OWIY CON 156 OHIH CON 157 IYEH CON 158 EHLL CON 159 IYUW CON 160 AXUW CON 161 IHWW CON 162 AYWW CON 163 OWWW CON 164 JH CON 165 VV CON 166 ZZ CON 167 ZH CON 168 DH CON 169 BE CON 170 BO CON 171 EB CON 172 OB CON 173 DE CON 174 _DO CON 175 ' note underscore ED CON 176 OD CON 177 GE CON 178 GO CON 179 EG CON 180 OG CON 181 CH CON 182 HE CON 183 HO CON 184 WH CON 185 FF CON 186 SE CON 187 SO CON 188 SH CON 189 TH CON 190 TT CON 191 TU CON 192 TS CON 193 KE CON 194 KO CON 195 EK CON 196 OK CON 197 PE CON 198 PO CON 199 RO CON 200 R1 CON 201 R2 CON 202 R3 CON 203 R4 CON 204 R5 CON 205 R6 CON 206 R7 CON 207 R8 CON 208 R9 CON 209 A0 CON 210 A1 CON 211 A2 CON 212 A3 CON 213 A4 CON 214 A5 CON 215 A6 CON 216 A7 CON 217 A8 CON 218 A9 CON 219 _B0 CON 220 ' note underscore _B1 CON 221 _B2 CON 222 _B3 CON 223 _B4 CON 224 _B5 CON 225 _B6 CON 226 _B7 CON 227 _B8 CON 228 _B9 CON 229 C0 CON 230 C1 CON 231 C2 CON 232 C3 CON 233 C4 CON 234 C5 CON 235 C6 CON 236 C7 CON 237 C8 CON 238 C9 CON 239 D0 CON 240 ' DTMF tones D1 CON 241 D2 CON 242 D3 CON 243 D4 CON 244 D5 CON 245 D6 CON 246 D7 CON 247 D8 CON 248 D9 CON 249 D10 CON 250 D11 CON 251 M0 CON 252 ' sonar pin M1 CON 253 ' pistol shot M2 CON 254 ' WOW EOS CON 255 ' end of string ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- eeAddr VAR Word ' address of speech element element VAR Byte ' speech element / code idx VAR Word ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- ' SCP strings NoPuMsg DATA "\0237J32H80NX", EOS ClearBuf DATA "\0RX", EOS ClearAll DATA "\08J0N1J0N11J0N2J0N12J0N3J0N13J0NX", EOS AllOff DATA "\08J0N11J0N12J0N13J0NX", EOS DialTone DATA "\08J0N1J350N2J440N11J18N12J18NX", EOS ' allophone strings Defaults DATA Reset, Volume, 127, EOS Welcome DATA WW, EH, LE, PA4, KO, AW, MM, PA5, EOS SpeakJet DATA SE, PE, IY, PA4, KE, PA5, JH, EY, TT, PA5, EOS Demo DATA DE, EH, MM, OWWW, PA5, EOS Parallax DATA PE, Fast, EYRR, UX, LE, AY, AY, KE, SE, PA5, EOS Basic DATA BE, EYIY, SE, IH, Fast, PA4, OK, PA5, EOS Stamp DATA SE, TU, AY, EH, MM, PE, PA5, EOS RobotSad DATA Reset, Bend, 0, Speed, 61, _B8, PA1, C9, PA1, Reset, EOS ParaPhone DATA Slow, D9, PA5, Slow, D1, PA5, Slow, D6, PA5, Slow, D6, PA5, Slow, D2, PA5, Slow, D4, PA5, Slow, D8, PA5, Slow, D3, PA5, Slow, D3, PA5, Slow, D3, EOS ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Setup: GOSUB No_PwrUp_Msg ' no "Ready" prompt ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: FOR idx = 0 TO 1 LOOKUP idx, [noparse][[/noparse]Defaults, Welcome], eeAddr GOSUB Play_String NEXT PAUSE 1500 FOR idx = 0 TO 1 LOOKUP idx, [noparse][[/noparse]SpeakJet, Demo], eeAddr GOSUB Play_String NEXT PAUSE 750 eeAddr = RobotSad GOSUB Play_String PAUSE 3000 FOR idx = 0 TO 2 LOOKUP idx, [noparse][[/noparse]Parallax, Basic, Stamp], eeAddr GOSUB Play_String NEXT PAUSE 3000 FOR idx = 15 TO 127 STEP 16 SEROUT Tx\Rdy, Baud, [noparse][[/noparse]Volume, idx] ' set volume level eeAddr = Parallax ' say "Parallax" GOSUB Play_String PAUSE 500 NEXT PAUSE 3000 eeAddr = DialTone ' simulate dial tone GOSUB Play_String PAUSE 4000 eeAddr = ParaPhone ' dial Parallax number GOSUB Play_String PAUSE 4000 GOTO Main END ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- ' Play a string of SpeakJet sound elements from EE. This subroutine ' uses flow-control to prevent sending elements when the SpeakJet ' buffer is full. ' ' -- put start of string in 'eeAddr' Play_String: DO READ eeAddr, element ' get element from EE eeAddr = eeAddr + 1 ' point to next IF (element = EOS) THEN EXIT ' end? if yes we're done SEROUT Tx\Rdy, Baud, [noparse][[/noparse]element] ' send element to SpeakJet LOOP RETURN No_PwrUp_Msg: ' clears PU Msg assignment eeAddr = NoPuMsg GOSUB Play_String RETURN
I had to use $0054 inplace of the Baud variable and I used a different pin (#9). I also used just the RCX line and removed the Rdy wire. Not sure why this worked but it did.
OS-X: because making Unix user-friendly was easier than debugging Windows
Post Edited (SSteve) : 6/4/2006 3:01:45 PM GMT
straight 9600 TTL by default. RS-232 has inverted logic levels but this isn't RS-232.
Using RS-232 on the SJ without some sort of level conversion chip (DS275 comes to mind)
will probaby kill your SJ RCX pin!!! If that happens you'll really be in bad shape.
Please note that the spec sheet for the SJ declares a NEED for a resistor attached to
the RST (Reset) pin for proper operation. The same thing applies to M0 & M1. I know
the diagrams for minimal connections in the spec sheet for demo'ing the SJ do not show
any resistors but that's intended for testing. PLEASE HEED THE DIRECTIONS IN THE TEXT.
SpeakJet schematics I've seen use resistors with a value of about 4.7K-ohms (YELLOW-VIOLET-RED).
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
I did not know that you needed a resistor for the reset pin as well as M0 & M1. I am going to revise my schematic to add resistors to these nets. Even though the SJ seems to work fine without them, I figure it's cheap insurance to add the resistors.
You betchya!!! Besides the spec' calls for 'em. Alas, they never say what value... :-|
If you've dealt with PIC processors before then keep in mind that the SpeakJet is really
just a preprogrammed PIC -- not some hotshot new piece of silicon. Pullups on the
event inputs would be considered a good thing too -- it keeps 'em from "floating".
Oh, it's been recommended that for Pin 4, place a small (~100-Ohms) resistor in series
with the pin to any input. Not necessary for operation but, since Pin 4 is the MCLR pin
(read "Master Clear") which is used when reprogramming PIC you probably don't want
some negative going spike to clear yer SpeakJet.
Have phun!
-Rusty-
EEPROM of the SpeakJet. After that's been done use the MSA command to say GOTO PHRASE 'n'.
This boils down to sending two characters, a ASCII-29 followed by ASCII-n, where 0<= 'n' < 16.
So two characters to the SJ will get a phrase played. This phrase can 'call' or 'gosub' to another
phrase in EEPROM and come back to the previous phrase; upto 3-levels deep so you can chain
these critters.
It's easiest to use the 'PhraseALator' program to get your phrases setup. Otherwise, see
page 11 of the 7/2004 version** of the manual about writing phrases to EEPROM on the SJ.
Alas, I don't have any code but you might check the Files section of the SpeakJet group on
Yahoo -- there may be some code there.
Any questions, just gimme a holler.
** Sorry, I'm at work right now but I thought there was a newer manual around but I can't
find it. I could be wrong.
-Rusty-
I will re-read the manual and see if I can get this going. I'll get with you if I can't get it to work.
