SHR SHL question
when shifing data in assembly, what is written to c, the last bit shifted off the 32 bit workspace or the first bit?
say you have %0100 and shift it right 3 bits, what would be written to c?
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
I'm not 100% confident, though. It seems like C should get shifted into. Experiment with it and see if you get the same results.
Don't forget that you have to append WC to the line when you want C to be updated.
OS-X: because making Unix user-friendly was easier than debugging Windows
······· ROR·· A,#3····wc············ 'rotate A right by three bits,·old bit 0 of A into C flag
········SHL·· A,#1····wc············ 'shift A left by one bit,·old bit·31 of A into C flag
······· SAR·· A,B· ····wc············ 'shift arithmetic A right by B bits,·old bit 0 of A into C flag
Chip Gracey
Can you take a look at the CarryInAsm.spin program I posted? I can't figure out why the "if_c" line is never executed. If I change it to "if_nc", it is always executed. I tried all kinds of combinations of shl/shr/ror/rol and different values for test_value. Edit: Never mind. Please take a look at this thread instead.
Post Edited (SSteve) : 6/1/2006 8:21:19 AM GMT
It's easy to understand why this carry behavior might cause confusion. I think the natural inclination among assembly programmers is that a shift of n followed by a shift of m would be equivalent to a shift of m+n in all respects:
shl dest, #5 shl dest, #4 wc is expected to be equivalent to shl dest, #9 wcThis is particularly vexing/confusing as it pertains to RCL and RCR. In fact, now I'm having difficulty understanding what's going on with these two instructions. Usually, rotates such as these include the carry bit in a circular shift. In the Propeller's case this would amount to a 33-bit circular register that gets rotated by the specified number of bits, leaving the last bit shifted into the carry intact. This is important because, including the carry, no bits get lost, and the instruction can be used for packing and unpacking data. (This would really come in handy in conjuction with MOVI and MOVS for packing bytes, since one extra bit could be "protected" in the carry from the 9-bit moves.)
So I'm wondering if maybe you could shed more light on the behavior of RCL and RCR and, perhaps, let us in on the reasoning behind choosing a "first-shift" behavior for the carry as opposed to the expected "last-shift" behavior.
Phil
