Counters stop working when I use the parallel LCD — Parallax Forums
SSteveSSteve Posts: 808
edited 2006-05-27 06:05 in Propeller 1
I'm experimenting with the Propeller's counters to try to figure out how they work. (I've managed to make a sawtooth wave!)
The only display device currently near my workstation is the parallel LCD on my PDB. Unfortunately, it seems that whenever I use my LCD object it causes the counter to stop working. I've attached a project that illustrates the problem. If you un-comment the lines in synth.spin that use the lcd object, the counter stops having an effect on pins 0 & 1.
If someone can take a look at this and tell me what I'm doing wrong, I'd appreciate it.
OS-X: because making Unix user-friendly was easier than debugging Windows
    edited 2006-05-27 05:34
    I'll look at this a little bit deeper when I get a chance.
    Is there any way you can re-arrange the hierarchy, so that "Debug_Parallel_Lcd.spin" is at least at the same level as "FrequencySynth.spin"?
    It might be that the "Debug_Parallel_Lcd.spin" uses one or both of the CTR's in some way that is clobbering the "FrequencySynth.spin" or vise
    versa. Remember that when you set a frequency with one of the CTR's using "FrequencySynth.spin",·it does NOT launch another COG. If there
    is a collision with the CTR's,·you may need to either launch "Debug_Parallel_Lcd.spin" or "FrequencySynth.spin" into a COG of it's own.
    This is just a speculation, I'm not at a computer right now that I can test your code with.
    Beau Schwabe
    IC Layout Engineer
  • Martin HebelMartin Hebel Posts: 1,239
    I haven't looked at the code, but when I've run into issues where starting something new caused problems it was typically due to the stack not being large enough.
    Martin Hebel
    Southern Illinois University Carbondale - Electronic Systems Technologies
    Personal Links with plenty of BASIC Stamp info
    StampPlot - Graphical Data Acquisition and Control
