BS2P-24 ver 1.5?
Does the PBASIC Editor v2.2.5 work with the BS2P-24 with the 'Parallax' branded·sx48? I checked here: http://www.parallax.com/html_pages/downloads/software/pbasic_2_5.asp·but it only mentioned the BS2pe.
Can you make some sort of announcement so someone else won't spend·2 hours trying to figure out why one bs2p programs just fine and the new one doesn't.
·· I don't understand...If you have V2.2.5 then you should be able to program the devices fine.· Is that the version you are using?
Chris Savage
Parallax Tech Support
csavage@parallax.com
·· Yes, you may need to do so.· This is one of those things where if you're in doubt, always make sure you have the latest and that will narrow down any potential issues.
Chris Savage
