Could some one please tell me why this scrolling text box doesnt work?
I'v tried everything I can think of, and I just can't see why the textbox doesnt scroll or work right when the text is less then the size of the box...
Just tossing my two bits worth into the bit bucket
KK
KK
VGA.STR(Text[noparse][[/noparse]Index])
supposed to be
VGA.STR(@Text[noparse][[/noparse]Index])
Also shouldn't
HoldChar := Text[noparse][[/noparse]Index + Size + 1]
be
HoldChar := Text[noparse][[/noparse]Index + Size]
I had not thought of that... thanks for the insight and I'll give it whirl!
KK
It's printing trash...
I changed the ref's to include @Text[noparse][[/noparse]Index]
I think it's got something to do with what is acutally created with STRING command, or what VGA.OUT is expecting
KK
As I figured out. Hence the VGA.STR call, now follow this: If I remove the [noparse]/noparse from the call, it prints!
Yes, if I do VGA.STR(@Text), it prints it all out.
But, if I do VGA.STR(@Text[noparse][[/noparse]Index]), I get "trash" on the screen.
I understand about the null terminator, that's how I'm setting the length of the string to print.
HoldChar = the original char, then I set it to null, print it, then reset it.
The question is simply this: Why can't I start outputing from the middle of the screen?
Eventually this routine will be included in something that gets its data from a device (like the directory of a SD device or something), which may or may not be be bigger then the scrolling window.
Oh, and BTW, thanks for helpin me out here...
KK
I modified your code a little bit, I believe this version is closer to what you are looking for.
Version 1: - Initial scrolling solution of modified code Version 2: - Added automatic character padding on either side of main scrolling text - "Title" or non scrolling text can be a null string size. - The main scrolling text can range from 1 character to 255 characters. In other words it can be smaller than the available scrolling window and still scroll from right to left.▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 5/23/2006 7:19:20 PM GMT
Thanks! I would have never thought of the byte command.
Slick..
THanks again all!
KK
THe new edits are much better... and slicker!
thanks again...
KK
