Question about using USB2SER to talk to BSII via debug terminal
I'm trying to use a USB2SER to communiate with a BSII over the serial com port. I'm using windows XP and have installed the driver and reduced the latency setting to 1 per the installation instructions. The comm port is set to 9600 baud, 8N1, no flow control.·On the debug screen, the key strokes are echoed back to· the screen and the RX and TX led toggle on the USB2SER, so it looks like the USB2SER is·talking to·the PC, but I seem to be getting any I/O from the BSII. The USB2SER is wired to a male DB9 connector, VSS to pin 5 of the DB9, TX to pin 2 of the DB9, RX to pin 3 of the DB9 and RES to pin 4 of the DB9. The eventual goal after I learn how to get the USB2SER to work with a BSII is to use the USB2SER to·replace the RS232 serial port on a Motorola HC11 trainer for a project at school. I'm using a BSII·example program DEBUGIN DEBUGOUT·program that I have attached. Any help or guidence I can get is immensely appreciated.
Jim K
Jim K
·· The USB2SER is not designed for this purpose.· The USB2SER communicates using TTL level serial, whereas the BASIC Stamp is expecting inverted RS-232 level signals.· If you had an OEM BS2 you could talk to it by bypassing the serial interface circuitry as shown in the Projects Forum.· You will either need to use a MAX232 or similar RS-232 level driver or get the actual FTDI USB to Serial Adapter we carry.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Thanks again.
Jim K
Thanks again Jim K
Chris Savage
