Propeller tool requests
A couple requests for changes to Propeller Tool.
1) Double-clicking to select a word should not consider the underscore character to be a word delimiter. Since the underscore is a valid part of a label or a number, the user is almost always going to want to select the entire number or label when double-clicking.
2) Unchecking "Color" in the print dialog should turn off the background colors everywhere, not just under areas with text. Ideally I'd like a separate checkbox to turn off just the colored backgrounds but leave syntax coloring enabled. It would use a lot less ink.
OS-X: because making Unix user-friendly was easier than debugging Windows
If I turn off the color print within its menu, any background that is unrelated to a particular character still gets printed.
Not only do I waste the color ink, it is even harder to read than plain old black and white.
For now, I just print in all color.
I may try cut and paste to Notepad as another interim remedy.
···· if I,m testing the RES cause the darn prop is not being recognized,I don't want to keep hitting OK all the time to reset it so I can send
···· a pulse to the darn thing,what is wrong with·putting a Delay of x amount before going away?·And it could be tick boxed as to
··· ·choice either/or and a drop down to set the delay!
http://people.delphiforums.com/cocokiwi/Image/picture.jpg
