Keyboard_iso
In the example file/pile, there is a program, Example08_KeyBoardInput.spin, that tests the keyboard and connections. This program uses an object keyboard_iso.spin that is not in the Propeller Tool 0.95.1. (The tool available is keyboard.spin)
Suggestions?
JameSX
Suggestions?
JameSX
Originally I was going to post my copy of "Keyboard_iso.spin", but I noticed several differences in the actual assembly code between the two.
The·original demo board (Rev A) has transistors that invert the clock and data signals to the keyboard, the new demo board (Rev C) does not
have this inversion.
Here is a revision of Example 8 using the object "Keyboard.spin".
I noted the changes as "WAS / IS" between the current version and the original.
Note: You may need to swap the cpin and dpin
Let me know if you have any problems.
Beau Schwabe
IC Layout Engineer
1+1=10
You make a good point that all of us should be made aware of.
If someone can confirm that my revision of Example 8 works with the (RevC) boards, then my answer
to your question would be yes.· "...can I develop using keyboard_iso and mouse_iso, then before
releasing replace the objects with their non _iso equivalent?"
Keep in mind also Paul, that the "_iso" object versions set the pin reference as a group, while the non
"_iso" objects set the specific pin.·· At least for Mouse and Keyboard ... Video still references a group
via a start pin of that group.
Beau Schwabe
IC Layout Engineer
Chip Gracey
This should be easy for everyone to figure out but...· I just received my Rev C Propeller Demo board and I was running through the demo programs.· The Keyboard_Demo program didn't work. ·The Keyboard_Demo is using dpin and cpin of 24, 25.· I noticed that these were the same pins for the mouse.· I checked the schematic and sure enough, the keyboard is on pins 26 and 27.· This simple change·and the program worked fine.
·'start the keyboard
· kb.start(26, 27)
Best regards,
Charlie
I would be willing to bet if you plugged the keyboard into the mouse jack with the original program it would also work.
Beau Schwabe
IC Layout Engineer
