Inexplicable voltage drop across high-current relay/mosfet controller
In the process of testing my controller (for which I'd liked to have used the DOS editor, metioned in the other thread, now I have to shuttle my board from the garage to my room every time I need to modify something
) I found that in one direction the controller works fine, getting me pretty much the input voltage back. But when I change the polarity with the relay, I consistently see a 0.3V drop on the whole system. I have no load on the thing except the voltmeter, so that should not be the problem. The resistances on all the wires seem to be fine, so I can't see a problem there either. On the other hand, I dont entirely trust my meter, so that may be the problem. That aside, can anyone see other problems?
Rafael
Sorry to bug ppl alot...this is my first project as mentioned before somewhere (although it has been dragging on for over a year, due to timelessness and partial Stamp-lessness, the current controller is not the only thing on the board)
Rafael
Chris Savage
Parallax Tech Support
csavage@parallax.com
Will try to post one later today
Rafael
Changing polarity on the relay?
Do you have a protection diode that you are forgetting about?
Chris Savage
Rafael
The basic design comes from Robot DNA "Building Robot Drivetrains"
I've had pains with the diodes, getting different information from all sides. The ones shown were recommended by PJ Allen (as far as placement goes).
Thanks for help. As I have mentioned before, this is my first motor controller, so please bear with me.
Rafael
The input to the FET (Gate) will be the DIR control.· Let's go this route --
Post Edited (PJ Allen) : 5/17/2006 11:42:59 PM GMT
Sorry[noparse]:)[/noparse]
Rafael
Post Edited (flyingfishfinger) : 5/17/2006 11:47:29 PM GMT
Post Edited (PJ Allen) : 5/18/2006 12:24:30 AM GMT
Thanks PJ for your insightful insights.
Rafael
