Ancient Op-Amp Spec Sheet
Folks -
Here's a rather interesting op-amp spec sheet from the tube to solid state transition era:
http://www.philbrickarchive.org/p2_differential_operational_parametric_amplifier.htm
Bruce Bates
<!--StartFragment -->
Bruce Bates
Don't visit my new website...
The Philbrick opamp sheet looks so familiar,there is probably a copy of it stuffed in the back of an old folder on my workbench.
The sheet says it's possible to connect the leads in any configuration without blowing it up.Try that with some newer stuff!
Thanks, Parallax!
