Problem with Boe-bot program...
Has anyone had this problem? When I load and run the program with the boe-bot set to 1, the program runs fine. But when I set it to 2, then the program only executes the first sub-routine and skips the rest.·The program is supposed to make the robot go front, left, right and back
·I tried loading it onto another robot and it works fine.
I think its a problem with the microcontroller? Or could it be how I built the robot?
Thanks for any advice...
OS-X: because making Unix user-friendly was easier than debugging Windows
