Demo board out!!
HUUUUUUUURRRRRRAAAAAAAAAHHHHHH!!!!!!!!!!!!!!!!
·Somebody said...
-Never Underestimate the power of human stupidity.
And here I just got done assembling my PropSTICK
You can use both in different ways.
·· OTOH, the Demo Board provides all the more advanced I/O ports that you would otherwise have to connect yourself.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Post Edited (inaki) : 5/12/2006 4:01:01 PM GMT
Ordered 4 Propeller Chips, shortly after release -- Still waiting
Ordered 2 PropSticks, 1 May -- Still waiting
Ordered Demo board yesterday.
As you can see, I am very excited about the propeller and have big plans for them.... Just waiting to get my hands on one.
Charlie
I agree, it would be a disaster for me to put all that into one breadboard. and it never would be only 3"x3".· I just think that both have their own appeal and utility.· If I wanted to do a huge blinking light marqee, I might want nearly all the 32 pins for that purpose, though alot could be done with synchonous serial outputs. [noparse][[/noparse]Any Las Vegas sign makers out there?]
You can easily use 5 or 6 Propellers in different formats·as the easy·interfacing with the power makes almost 'instant applications'.
1. O scope; 2. Logic Analyser; 3. Midi applicaton; 4. RS-232 terminal; 5. Video gamer; 6. and so on.
Posponed the vacation to Bali this year. Will play with a Propeller instead and learn something useful. ·Who needs the mosquitoes and coconuts?·· Waiting a bit to buy two Propeller demo boards [noparse][[/noparse]I want to give these to people and I need a complete package], the 2.5 video display, and maybe Andre LaMothe's creation.
After I·purchase all·that, I suspect Parallax will launch·the 64 pin version [noparse][[/noparse]a TurboPropeller?] and I will be wondering what to do.
Post Edited (Kramer) : 5/12/2006 5:51:56 PM GMT
But of course I ordered a demo board already [noparse];)[/noparse]
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
COMING SOON "SD DATA LOGGER" www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
Me, too...
Found the package waiting for me when I got home at 17:00
(nice surprise after spending 2 hours at the dentist...)
Now I'm hoping for bad weather tomorrow so that I have an excuse NOT to fix my car, and instead tinker with the propeller...
Don't visit my new website...
I am ordering 3 Propeller Demo Boards today and the 2.5" monitor.
Ouch.
Yikes. Whoopee! ! !
{I can print my own documents and make my own CDs later for the ones to gift to people}.
BTW, has anyone found a way to use Bean's 4-digit SPI numerical LEDs with the Propeller yet?
·FREE SHIPPING on big orders [noparse][[/noparse]over $200USD] for Continental USA only
You lucky guys.
Post Edited (Kramer) : 5/13/2006 8:58:01 AM GMT
· It's next on my list...
Bean.
Here is the HC4LED object to control the displays.
I'm not sure if this is appropriete to submit since it is useful only for my display module ?
Comments welcome, I've only had the propeller for a couple days. If·I have gone astray please let me know.
Edit: Fixed cnt rollover
Bean.
Post Edited (Bean (Hitt Consulting)) : 5/14/2006 1:06:09 PM GMT
cheers ... brian riley, n1bq, underhill center, vermont
See the K107 Serial LCD Controller at
www.wulfden.org/k107/
Chip Gracey
The same for LED series current limiting resistors. I see values from 220 ohms through 1K. On the newly released demo board the values are 240 ohms, which makes some sense to me in that your are limiting for a 3.3 volt system not 5 volts. But again, what considerations are there in this range of possible values.
The different between 5K and 10k is almost nothing logrhymically.
I believe the choice of using the 4.7K on the PropSTICK was because people may use more than one I2C device and less pull-up resistance would be less tempermental. But, if you really do all the mathimatical comparison, it really doesn't amount to anything significant.
Technically, there is a co-relation between the pullup resistor and the speed of the circuit., but since I2C is not very fast there is likely little concern. I would have to think a bit or go read which direction does what. This has been discussed many times, in many threads.
The reason to use 4.7K is that manufactures of resistors don't generally provide a 5K at 5% tolerance. It is hard to buy certain sizes exactly. The usual reason for selection choice of something this close is that the supplier or your cupboard has a huge pile of one or the other.
I find myself using anywhere from 220 to 510 ohms on LEDs for similar reasons.
330ohm is generally considered the safe limit for 5V LEDs, but different colors are electrically different. The 3.3volts allows for a lower current limiting resistor [noparse][[/noparse]so the 240ohm is used], but many times I am not too concerned about the welfare of an LED. I usually wear out the leads before I burn them up on breadboards.
Does this mean I can use the more common (and locally available) 220?
Just tossing my two bits worth into the bit bucket
KK
Chip Gracey
I even have some new blue/white LEDs that work fine at +5 without any·resistors. Still, the 470 ohms is a good start when guessing and you don't know the color.
Kaos Kidd,
you could try 220ohms as Chip has mentioned several times that 5% tolerence on the video resistors is okay. But you are reaching closer to 10%. Can you find two 120ohms and put them end to end?
Be aware that when you have a voltage divider circuit of any sort, it might be more prudent to go UP [noparse][[/noparse]say 270 ohms] rather than down as you may suddenly find yourself burning up resistors [noparse][[/noparse]and maybe something else].
I found that I could not buy the 5% 240 ohms, but that it is easy to buy 1% 240 ohms. This is a double inventory thing. Why should retailers carry all those odd numbers in low tolerances when the buyer wants a more exact number?
Post Edited (Kramer) : 5/21/2006 2:02:31 PM GMT
Sorry, I missed your reply... I ordered the exact ones as used on the dev board... it just took some time to get here... I'm using the pots for temp / expierments when I don't have the correct size resistors..
THanks for the info.. I heed to do all that I can to prevent "hardware" errors from working into what I try...
KK
