Elephant stimulus, and beyond...
Friends,
Some of you might remember a previous post where a cousin, and
her graduate student, pulled me out of retirement to do some hardware
and write some Basic Stamp code to help them with an experiment
aimed at understanding whether or not elephants respond to sound
in an operant conditioning experiment.
Thanks to your help, the project is done.· And just needs to be put in
a box that they can use in the field.
But I'm still not all that happy with it.
I believe that true interrupts are not supported.
Is that true?
What I'd like to do is put the controller into low current draw mode until
either·of two switches is pressed, then go off to a subroutine, and then
go back to sleep.
Is that possible?
--del
Which end do end-users use?
Is that true?
go back to sleep.
Is that possible?
--del
Then, at the end of your code, call a "sleep".
I might try that, but at the moment I'm under the gun to
get a prototype in their hands by this weekend.
Worth thinking about tho...
--del
Although there is more then likely a bug in this as during the time the switch is thrown the stamp will be forced to repeatedly reset, hence when the switch is open the reset will stop but there will be no closed switch to satisfy the IF conditional statement.
Maybe some circuits will have to be built to pulse the reset pin once quickly. (Im not in a thinking mood today but maybe you could somehow use a small capacitor that charges while the switch is in open state and discharges through the switch when closed to control a current to the reset pin. quick pulse, might work!).
Good luck though.
But it's a problem I've stopped worrying about.
That 9V battery doesn't seem to want to die!
Myabe I should hook it up to the power supply to see
how much current it actually draws?! '-)
--del
