PSC servo position parameter
1) for the PSC to control servo position the range (250-1250) corresponds to 0 to 180 degrees of servo rotation or 0.5ms to 2.5ms pulse width. Actually where is this parameter range 250-1250 come from? why it is not 0-1000, or other value? Does it indicate anything?
2)·What is the chip at the middle of the PSC? Is it some kind of pulse width generator? Can I find block diagram of that chip?
Thanks for helping
Thanks for helping
Now, different hardware uses a different 'tick' size, in order to generate those pulses. For instance, the BS2 uses a 2 uSec unit for it's PULSOUT command. So PULSOUT ServoPin, 750 results in a 1.5 mSec pulse.
I assume the 'chip in the middle' is some flavor of PIC or SX chip.· It's programmed to communicate with your BS2, and maintain multiple positioning signals on up to 16 servo connections.· So it's not a simple "comparator", it's a microprocessor.
Also, the 'tick' size for the PSC IS '2 uSec' -- so a value of 500 to 1000 will get you the 1.0 to 2.0 mSec outputs.· True, the documentation does say you can use 250 -- but I wouldn't.· Perhaps that was for another time, when the 'tick' size was 4 uSec.·
Post Edited (allanlane5) : 5/2/2006 6:59:05 PM GMT
The range of 250-1250 are determined directly from the resolution or 'tick' size.
If your servo can accept a pulse from 500uS to 2500uS and your resolution is 2uS, then 500uS/2uS = 250 ticks , and 2500uS/2uS = 1250 ticks.
Keep in mind that not all servos are created equal, and some can barely except a pulse width range of 1000uS to 2000uS (or ... 500 to 1000 ticks)
'Ticks' = [noparse][[/noparse] Desired Pulse width (uS) ] / [noparse][[/noparse] Pulse resolution (uS) ]
Beau Schwabe
IC Layout Engineer
And the Parallax servo's use the 1 mSec to 2 mSec pulse range. So feeding them a pulse of 500 uSec might not be a good thing. In fact, could it damage the gearing? I don't know.
Bottom line -- read the Servo vendor documentation for what pulse width your particular Servo's require. Then convert those into 'tick' values using the 2 uSec per 'tick' of the PSC documentation. In engineering the rule is Trust, but Verify!
P.S.· Oh dear.· I just tried to find the spec for the Futaba 3003, or Futaba 148 (I believe the '148 is the one Parallax sells).· The Futaba site doesn't specify, that I could see.· There was a site that said they go from 320 uSec to 3 mSec for full left to full right -- so the 0.5 mSec to 2.5 mSec should work just fine.
Sorry about that, all.
Post Edited (allanlane5) : 5/2/2006 7:45:15 PM GMT
500 means 1.0 ms and 1000 means 2.0 ms
For the javelin I wrote a class that converts between angles and position values.
As I understood the PSC manual the servo 180 degree range was covered
by the 250-1250 position value range.
Am I to understand that for Parallax servos the 180 degree range is
covered by the 500-1000 position value range?
(Using angles makes the main program independant of position values
which are servo dependant)
regards peter
For CR servos the values correspond to direction and speed?
So 500 corresponds to full rotation speed anti-clockwise
and 1000 corresponds to full rotation speed clockwise
and 750 corresponds to stop?
From 750 down to 500 increase RPM acw, from 750 to 1000 increase RPM cw?
Is this increase lineair with value?
What is the full speed RPM value?
regards peter
I would assume that not all servos are created equal, and that you can not assume that between
mechanical positioning and component tolerance that 0-180 Deg on one servo is going to equal
0-180 Deg on another servo. I understand the need to normalize the data into Deg, but it seems
to me that there might also be some loss through the conversion between the servo pulse width
and a Deg angle. I personally like to try to do things as a percentage (0-100%) when trying to
make a code module portable to other applications.
For CR (continuous rotation) servos, there is a narrow window (again varies from servo to servo)
away from center position that the 'speed' can be controlled.
Note: The larger differences between servo's will be from manufacturer to manufacturer or the
difference in the servo model numbers from the same manufacturer.
Beau Schwabe
IC Layout Engineer
the conversion is actually done using a Pmin and Pmax value,
corresponding to 0 and 180 degrees. One needs to measure
the Pmin (full left position) and Pmax value (full right position) for each servo.
On CR servos: does this mean there is no real speed control, just direction control?
(pulse < 1.5 mSec·then dir = acw, pulse > 1.5mSec then dir = cw)
regards peter
There is 'speed control'- but keep a few things in mind: the deltas off of the 1.5 (750) and speed are not a linear relationship. That combined with tolerance differences in components used in the servos, and you need to be careful when trying to match the sides in a wheeled robot, for example.
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
regards peter
Now, there is a modification you can make to the electronics inside the servo, which will broaden the speed curve. But it's really non-trivial (involves soldering a new resistor and capacitor in the right places).
I'm new to this programming stuff of Basic Stamp. I need some help in programming two servos to make my robot move forward (or backward). I'm using BS2p24 microcontroller and Board of Education Rev C. I also use the Parallax Servo Controller (#28023). I've tried to program it but all i can do is making the servo rotating in the same direction. I know that in order to make the robot move forward (or backward), one servo must rotate clockwise and the other must rotate counterclockwise, but i really don't know how. What position should i put in my program?(GWS servos are used).
