Fuel tank sensor question — Parallax Forums
wolffwolff Posts: 43
edited 2006-05-09 17:16 in General Discussion
I have a fuel tank (diesel) that uses a dipstick about 1/4 inch in diameter. I would like to make something that the stamp could read that would fit into the dipstick hole to tell me when the tank is full. It does not have to be terribly accurate. I just need to know when the level·is with in an inch or two from the top.
Any ideas???
J
  • A.C. fishingA.C. fishing Posts: 262
    edited 2006-05-07 12:27
    Thought:
    Put an IR detector and reciever two inches from the top of the tank, each on opposite sides of the tank. Have the stamp send the LED the harmonic, and the phototransiter will receive it, and tell the stamp. But when the diesel comes up to that level, the connection will be broken, and the stamp will know.
    -Also consider the fact that diesel is highly explosive, and one spark can mean poof jumpin.gif car, garage, and if you are near, you.shocked.gif·shocked.gif· I wouldn't do this , because of this risk, but if you want to use waterproof parts, work on a totally empty tank(without fumes!), and be very careful.
    skull.gifskull.gifskull.gifskull.gifskull.gifskull.gifskull.gifskull.gifskull.gifskull.gifskull.gifskull.gifskull.gif
    Somebody said...
    -Never Underestimate the power of human stupidity.
  • Robert KubichekRobert Kubichek Posts: 343
    edited 2006-05-07 15:56
    wolff said...
    I have a fuel tank (diesel) that uses a dipstick about 1/4 inch in diameter. I would like to make something that the stamp could read that would fit into the dipstick hole to tell me when the tank is full. It does not have to be terribly accurate. I just need to know when the level is with in an inch or two from the top.
    Any ideas???
    J
    Thats an easy one, use a 1/4 tube, open at bottom and close to the top of tube that allows float movement, put a pin across bottom to hold float, the float would either trip
    a switch, or break an ird dectector pair, or if a little magnet was placed in top of float , it would trip a hall sensor... I have seen many
    rare-earth magnets that would easily work, and the are very powerful!! I have several that I scrounged from old scsi hard drives...
    about 3/16 diameter, and 5/32 in length, they are very powerfull! You can take it from there. smilewinkgrin.gif
    Post Edited (Robert Kubichek) : 5/7/2006 5:00:05 PM GMT
    edited 2006-05-07 18:25
    http://forums.parallax.com/showthread.php?p=582014
    edited 2006-05-07 21:44
    I would stay away from anything electical, even mechanical systems which can produce static electricity. Gasoline is extremely volatile, and when it is in vapor form the slightest spark will ignite it. If I were to try something like you are, I would create a closed system pressure sensor. In the bottom of the tank fasten a chamber which has a diaphram that is quite flexible, all materials used has to not corrode in the presence of gasoline. The chamber is connected to a hose which feeds up through the hole, where a pressure sensor is coupled to the hose. The entire assembly has to be air tight. This way there is nothing electrical inside the tank, and the only moving part is the diaphram which doesn't rub up against anything, so no sparks are produced.
    1+1=10
  • wolffwolff Posts: 43
    edited 2006-05-07 22:38
    It's· diesel.
    I like the float/magnet/hall effect idea best.
    Thanks to al!
    edited 2006-05-08 00:24
    Sorry, missed that point. Ok so spark ignition is less likely, but still possible. Be sure to properly insulate all metal surfaces. 62C is a fairly high flash point, but it is by no means impossible to reach, especially if you short something.
    1+1=10
  • BongoBongo Posts: 65
    edited 2006-05-08 01:10
    In the aircraft I used to work on, they use capacitive sensors - for Jet A which has to be close to diesel.
    I did a lot of experimenting with the Q prox IC's (that I do believe parallax can provide) some time back for water level detection. Whilst they worked very well, they failed in range of temperatures required.
    If it where me, I would probably be looking real hard at the pressure switch, for it's known reliability and cheap price.
    The problems assosiated with using any voltage inside a fuel tank are probably more to do with your insurance companies' attitude than risk of detonation and colorful destruction.
    bongo
  • BullwinkleBullwinkle Posts: 101
    edited 2006-05-08 01:25
    Diesel has a much higher flashpoint than petroleum. I'd experiement with a basic moisture probe. Cut 2 peices of metal a few inches long and place them in the top of your dipstick. Connect one to ground and the other to an I/O pin on your stamp. Connect a small capacitor in parallel between the probes and use the RCTIME call to check the resistance between the probes (after charging up the cap). Air will have a very high resistance compared to diesel. When you read a lower than air resistance you know there is diesel at the top of the tank. I doubt 5v would pose an ingition threat - but I'd do the experiment just to be sure!
    The only potential problem I can see is the fact that diesel is very oily, and a layer of diesel will remain in contact with the probes very after the level has dropped. But the resistance should still be much higher than if the probes when in diesel fuel.
    edited 2006-05-08 01:42
    Ok... Here's the rest of the story...
    This application will be used on my sailboat. Right now fueling requires two people. One to continually dip the tank while the other adds fuel (from the deck fueling port.) I would like to set it up so I could·remove (unscrew and pull out) the dipstick and screw in my contraption... which will have a LOUD audible alarm to tell me when to stop adding fuel. Then·I·can remove the contraption and replace the dipstick... And move on to the next tank!·
    I'm not worried about insurance or fire. Low voltage and good engineering will mitigate the fire/explosion hazard.·
    Any further ideas would be greatly appreciated!
    Sincerely,
    J
    edited 2006-05-08 01:57
    wolff said...
    Ok... Here's the rest of the story...<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com[noparse]:office:[/noparse]office" /><otongue.gif></otongue.gif>
    This application will be used on my sailboat. Right now fueling requires two people. One to continually dip the tank while the other adds fuel (from the deck fueling port.) I would like to set it up so I could remove (unscrew and pull out) the dipstick and screw in my contraption... which will have a LOUD audible alarm to tell me when to stop adding fuel. Then I can remove the contraption and replace the dipstick... And move on to the next tank! <otongue.gif></otongue.gif>
    I'm not worried about insurance or fire. Low voltage and good engineering will mitigate the fire/explosion hazard. <otongue.gif></otongue.gif>
    Any further ideas would be greatly appreciated!<otongue.gif></otongue.gif>
    Sincerely,<otongue.gif></otongue.gif>
    J<otongue.gif></otongue.gif>
    As a further note, if the float was made right, there would not be ANY wires inside the tank.
    It would be very easy if it was a straight line/shot into the fuel tank. smilewinkgrin.gif
    edited 2006-05-08 02:11
    It is. The only real limmitation is the dipstick whole size... about 1/4" or 3/16. It's do-able with the right material.
    edited 2006-05-08 02:48
    wolff said...
    I would use aquarium tubing, as it comes in several different sizes, is rigid, and clear, and cheap! smilewinkgrin.gif
    The smaller diameter sealed on the bottom would make a good float.
    It could be as long as needed to provide floatation, it should clear the tank so electronics are not inside.
    I would measure diameter of dipstick opening, and have the outer tube to be slightly smaller, with a smaller float tube that freely slides inside.
    The longer the inside tube, the more the flotation, also the whole assembly can be as long as the tubes you get.. yeah.gif
    edited 2006-05-08 03:20
    Robert,
    ·· Won't the fuel break down the aquarium tubing?· It seems I did a test using this tubing for fuel line although I could be wrong.· It was many years ago.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
    edited 2006-05-08 03:52
    Chris Savage (Parallax) said...
    Robert,
    Won't the fuel break down the aquarium tubing? It seems I did a test using this tubing for fuel line although I could be wrong. It was many years ago.
    Hmm confused.gif didn't think of that, I know after a while gas will make it softer, BUT it will not be imersed in the diesel fuel for very long..
    Also I have seen teflon tubing used in labs that would work fine, but it is not translucent, and the cost is much higher! shakehead.gif
    idea.gif Heck, it could be made out of aluminum tubing, some old tv antenna would work fine....
    Matter of fact, it would be better, as it would not be affected by the fuel at all nor change the magnetic field...
    And you CAN solder it with the right past/solder combo ( I've done it to repair ham antennas)! smilewinkgrin.gif
    I have some aluminum tubes that make great blowguns, and are about 1/4" diameter....
  • nick bernardnick bernard Posts: 329
    edited 2006-05-08 18:51
    in the marine service industry we use murphy el150k switches for fuel level alarms. they have a small knob for easy testing. but you will have to thread your tank.
    the switch can directly drive an audible or you can add it to your machinery alarm system if you have one. or you could make your own with a stamp.
    http://www.fwmurphy.co.uk/products/fluid_level/fluid_l150_el150k1_el150ex.htm
    http://www.pps-bv.nl/gb_frame_levelswitches.htm
    engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
    edited 2006-05-08 19:18
    Robert,
    I think you are correct that aquarium tubing is incompatible with solvent fuels. But there are types of tubing which are compatible, medical supply and I think even smallparts.com carries the type.
    1+1=10
  • steve_bsteve_b Posts: 1,563
    edited 2006-05-08 19:28
    So you don't necessarily care how much is in the tank....just that the tank is full and you can stop filling?!
    Our riding lawnmower (john deere) has a little contraption on it's fuel cap cover. It's a foam block that is in a cage. When you put the cap and assembly on, the foam floats to some degree and causes a mechanical deflection on the top of the cap (where it indicates how much gas is in teh tank).
    All you need to do is get a little bobber in a similar-like cage. set it in your tank in such a way that the ingoing fuel doesn't disrupt it (too much) and then put a little switch at the appropriate level in the 'cage' so that as the fuel rises, so does the bobber and then the switch will send an alarm.
    Diesel isn't likely to go boom unless you have it under pressure and high temps....but I'd still go to some good effort to protect my wires/contacts to prevent any problems.
    Just remember, we are all hobbiests here, your actions are your responsibility.
    Steve
    "Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
  • Lee HarkerLee Harker Posts: 104
    edited 2006-05-08 20:25
    Wolf,
    I saw an idea a while back that would probably work for you. I don't remember where I saw it though. It used a reflective led-sensor combo connected so it was looking down a length of plexiglass or similar plastic rod. The opposite end of the rod was cut at a 45 deg. angle cleanly. The refraction index of rod to air was very different and the 45 deg. cut was like a mirror and the light bounced back. When the rod was immersed in a fluid, the 45 deg. angle looked clear and the light didn't bounce back. Therefore you have a detector with no moving parts and no sparking. Just make the rod the correct length for the level you want.
    Credit goes to whoever dreamed this up before me.
    Lee
    edited 2006-05-09 03:46
    Paul,
    ·· Yeah, I knew there were some...Back in my R/C days I had to run the little rubber fuel lines from the tank to the engine...I don't know what that stuff was but it survived that fuel (which is not gasoline or diesel but...).
    Chris Savage
    edited 2006-05-09 04:49
    Glow fuel, I believe (typically methanol/nitro-methane/castor oil).
    BTW, I like the plexi-rod reflection idea, quite ingenious.
    1+1=10
    Post Edited (Paul Baker) : 5/9/2006 4:52:39 AM GMT
    edited 2006-05-09 05:24
    You can count on the forums to generate some intersting approaches to things sometimes.·
    Chris Savage
  • stamptrolstamptrol Posts: 1,731
    edited 2006-05-09 12:22
    I assume the fuel line comes off the bottom of the tank? Put a pressure transducer ( or a mechanical gauge with a contact on it) and read the pressure as the tank fills. As long as the tank has a reasonable depth when full compared to empty ( say 12" or so ) you'll have a large enough signal to work with, without putting stuff inside the tank.
    Standard transducers go down to 2 psi ful scale which should be in the ball park.
    Cheers
    edited 2006-05-09 14:49
    Is the tank vented? Is it a 2-way vent? You need to replace the used fuel with air, but you also need to vent air out when the temperature goes up and gases build up.
    If the tank is vented, then you could probably use a 'weighing' transducer.
    We actually have a rain gauge that works with the vibrating wire setup.
    The wire is vibrating at, pick a number, say 1kHz (you can hear it)....as the bucket fills with rain water, it pulls on the wire and the string tightens which causes the frequency to go up. We then measure this frequency and determine how much went in the bucket.
    Not sure if you could emerse a long vibrating string in to your fuel and use it like a guitar string....instead of your fingers holding the string for a given note, the fuel (at whichever level) would dampen the virbration enough to give you a note back.
    We had a small vacuum deposition chamber in college (we made some small silicon wafer setups). Well, basically under a high vacuum we'd evaporate aluminum in a tungsten filament. The aluminum would then coat the wafer. Problem was, you kinda guessed at how thick the layer was with the time you left it in there (and the amount of aluminum too). Well, the prof took a crystal from his old tv and peeled part of the can back and stuck this in the deposition chamber. The idea then was to monitor the frequency of the crystal while the aluminum was depositing. For every Angstrom (I think that was the right word -- molecular level of aluminum deposited) of AL that ended up on the crystal, the frequency would drop by 1kHz (guessing). Was quite need....but there was a lot of runaway, so you had to pull the plug before you reached your thickness, and hope that it coasted to what you wanted.
    (Sorry....was totally off topic!)
    Steve
  • David BDavid B Posts: 593
    edited 2006-05-09 15:42
    When I was a kid, our house was heated with fuel oil. The 500 gallon oil tank was located under the house, and was filled from outside. Two pipes led from the tank to outside - one for filling, and one that had a simple sort of whistle on its outside end.
    When the tank was refilled from outside, the guy would pump in the oil until the second pipe stopped whistling.
    I'm not sure exactly how the tank was designed - whether there was more than one air vent in the tank, or how the whistle pipe was attached. I imagine the whistling pipe entered the top of the tank and stuck a few inches below the top, so when the fuel reached it, air would stop leaving the whistling pipe, but there must have been some kind of allowance for accepting a few additional gallons.
    Maybe something like that whistling pipe would work in your case. Sorry, this method doesn't require your Stamp.
    David
    We use the same setup with our diesel genset at work.
    To use a stamp, you could connect a little windvain to a microswitch (if the air is powerful enough coming out) and then have the stamp monitor the switch setting.
    You could also take a tachometer and a propellor (not the new IC Parallax is selling [noparse];)[/noparse] ) and put it in the airflow area and monitor it's output voltage.
    Steve
