IDE copy/paste ? — Parallax Forums
IDE copy/paste ?
inakiinaki Posts: 262
edited 2006-05-07 16:33 in Propeller 1
I have realized that the standard CTR+INS to COPY a part of the text·does not work on the IDE.
The SHIFT+INS PASTE function does works though. Which is the equivalent COPY hotkey in the IDE then ?
    edited 2006-05-07 16:28
    I've always used Ctrl-X to cut, Ctrl-C to copy, and Ctrl-V to paste. ('Probably a throwback to WordStar.) These work with the IDE.
    The Propeller tool uses standard Windows Cut/Copy/Paste key combinations. If you hold the Alt key while dragging a selection, you can select a "block" from several lines; this is convenient for moving drawings and comments.· See chapter 2 (also online as a Help file) for details.
    Jon Williams
