Connecting and using LM34-DZ
http://info.hobbyengineering.com/specs/NATSEMI-LM34.pdf
Has anyone connected a LM34-DZ to a javlin?
If you did could you explain·how and what I need to do to use one of these probes.
Thanks bob
Thanks bob
http://ranger.uta.edu/~huber/cse4392_SmartHome/Lectures/Sensors2.ppt
Basically, you would use the ADC vp to measure the LM34 output voltage.
regards peter
I'm using a MAX1270 12-bit analog-to-digital converter (specifically the MAX1270ACNG) to connect a similar temperature probe to the Javelin Stamp. This could be used to directly read the voltage but I use an LM324N op amp to scale up the voltage to provide better resolution.
Let me know if you have any questions about this approach.
Scott
