Motors for larger robot
I'm working on a fairly large robot that will use a PC for the main processing and a cluster of stamps with serial communications to handle specific tasks like servos, compass readings, bumper sensors, sonar (with PING), and robot movement.· I want to use two HB-25 Motor Controller's to control 2 DC motors (differential drive steering) but I'm having trouble finding reasonablly priced motors.· Does anyone know of a good source?· The robot will be indoors and should finish out at between 50 and 100 pounds and I plan to use a 12VDC 21AH battery.
http://www.markscheeff.com/etc/links.html
1+1=10
Post Edited (Paul Baker) : 4/21/2006 2:31:38 PM GMT
Shopping by internet may or may not be as good.
I lived in San Francisco and had to specifically go to Oakland to locate things. At other times it was necessary to go down to Silicon Valley.·
There was next to nothing in San Francisco proper and driving one to two hours really did save money.
1+1=10
Thanks, Parallax!
If you scroll down, one of the reviewers has tutorials on how to use the motors (create mounting brackets, linkages, etc): www.scary-terry.com/wipmtr/wipmtr.htm
The RS-545 motor with 100:1 gear ratio looks good but I calculate it would deliver·3800 oz-in minus friction loss (please point out any errors in logic). I could get that in a 256:1 ratio for 9728 oz-in.
The windshield wiper motor sounds great for the price.· I can't do any calculations for it but I see a review that says it moved a bot that was near 200 lbs.
It also looks like I could use one Motor Mind C ($55) instead of·two HB-25 (~$99)·controllers.
I guess now I'll have to pick some wheels and do some speed calculations to see what suits my bot best.· Also, the wiper motor sounds great but the RS-545 has more specs I can work with.· I looked for wheel chair motors but couldn't find anything as good as these 2 motors.
Decisions, decisions.
Thanks for your help guys.
I believe I need to clip the braided wire connected to the lug at point C but I'm not sure.· I know I need another wire (probable black) to go to the motor controller but I'm not sure where to attach it in the motor.· Also, is it likely that I could lift this board out if I removed the brushes?· Any help anyone can offer will be appreciated.
http://www.surpluscenter.com/sort.asp?numrec=59&sort=1&search=dc%20gearmotor&UID=2005040807153250
I used 4 of the windshield wiper motors rated at 24 volts, but I am operating them on 12 volts.
My robot "Robochild" weighs in at about 50 pounds (pictured at left)
Deno
Then I used the same arrangement with a 48 lb box of books and the motor lifted it off the ground with no indication of stall.· I'm sure 2 of these will move my 70 lb robot with no problem.· In fact, they should be able to lift it off the ground.
