what should i use
not shure if this is the right area but here it is.
in your opinion which is better, the PIC, Basic Stamp,SX.or you could list your favorites
Chris Savage
Parallax Tech Support
csavage@parallax.com
Jon Williams
Jon Williams
(I a couple of secondhand programmers and a ton of printouts of datasheets to prove it)
THAT ended up as a hair-pulling exercise(luckily, I have enough hair...)
Then I stumbled upon the Basic Stamps.
*Does the Happy Beagle dance*
Until recently the BS2p was my favorite, with the BS1 as a firm second.
(You just got to love the BS1. So small, versatile, and runs forever on a simgle button-type battery if you just cut the right wire)
Now?
Definitely the Propeller, even though mine hasn't arrived yet.
Note, I also considered the BasicAtom and a couple of others instead of the BasicStamps, but what won me over wasn't processing speed, available memory, or price, but the incredible support of not just Parallax but the entire community.
(That was back when Parallax had a mailinglist. Now with this forum its even better)
In short, to find out what is the best mcu, you need to consider a lot of factors:
Price, processing power, memory space, number of I/O-pins, built-in functions(like AD/DA converters, Real-time clock), power-requirements, useability, support, fitness for purpose and probably a few others...
Now, the problem is that very few people considers all the same factors as important as you may?
Some look at price first( and goes for the PIC), others wants good support and so on.
And there's the 'fitness for purpose' factor. If you just need it to blink a few LEDs at intervals, the BS1 may be a bit more costly than the PIC, but it does the job admirably, and so very, very easily.
Don't visit my new website...
PIC:
Although their starter kit is cheap, they limit you to programming small 8-pin or 14-pin parts.· You can modify it, buy other unsupported programmers, but it's a pain.· Better programmers, debuggers, and software·are expensive, especially for a hobbyist.· PICs are SLOW unless you get into higher end models.
SX:
By far my product of choice.
SPEED
SUPPORT (!!!)
LOW-COST (affordable eval boards, plenty of cheap accessories, etc)
EASY TO PROGRAM (INCLUDING FREE SX/B)
HTH,
Keith
