Custom Chars in the IDE -> How do you draw a switch in the IDE using the custom
As silly as that sounds, it illudes me as to how to make a simple pull up/down switch in the IDE...
Just tossing my two bits worth into the bit bucket
KK
KK
·· Just click Help\View Character Chart and click on the symbol you want.· It will·insert at the current cursor position.
Chris Savage
Parallax Tech Support
csavage@parallax.com
3.3v  └── Momentary Switch ─┳─────── P0  10KΩ 3.3v   └── Momentary Switch ─┳─────── P1  10KΩ ▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
KK
KK
Jon Williams
Post Edited (Phil Pilgrim (PhiPi)) : 5/5/2006 6:29:44 PM GMT
KK
And, can someone plesase tell me how to insert the image directly into the post... so it's not just an attachment?
Thanks every one...· Check ya all out later... I'm on my 2 hour commute home now...
(to build my Propeller dev board!!!)
KK
Post Edited (Kaos Kidd) : 5/6/2006 12:38:02 PM GMT
1+1=10
It worked!
[noparse]:)[/noparse]
KK
#1 Created a Power supply for my dev "system" from a old ATX working power supply. All the outputs are off. The 3.3V is 2.89, the 5V is a 5.89, the -5 is at 5.21, the 12 is at 10.89 and the -12 is at 7.86. I think it's because I used a 10 ohm, 10watt power resistor. I'm going to have to research this, unless someone has the answer. The power supply has a 5V SB output, which I have no idea what it is used for.
#2 Wired up my "primary" breadboard for the propeller. (I'm still doing the voltage checks, but I'm almost ready to power on with the propeller & eeprom!
KK
·· 5V SB is Standby Power for keeping keyboards, mice or other peripherals powered to use as a wake-up device.·· That lead should always have 5V when the supply is plugged in.· You can't very well wake from keyboard, for example, if you don't have the device powered.· But it seems we're getting off topic in this thread...
Chris Savage
KK
