Lots of LEDs
Hello all,
I am doing a project with around 100 LED's!· I want to be able to control each one separately and be able to turn it on or off with a button.· I know I can use Decoder chips to control 7 LED's but I want to use the SX chip to control multiple decoder chips, which will control each of the 100 or more LED's!· Is this possible??
Any help would be appreciated!
Joe
Joe
Jon Williams
How far do you think I could go with this before the SX is overloaded?
Joe
Jon Williams
They can be daisy chained too but I have yet to get it to work right.
Jon has a Nuts and Volts article about interfacing·it with a BS2.
http://www.parallax.com/detail.asp?product_id=603-00001
Thanks.
It's not clear from your post whether or not you need more than one LED on at one time. If you only need one (any one that is), then you can achieve that from a single SX, using only 11 port bits. In fact that will drive any one of 110 LEDs. You also could vary the brightness of each one.
If you used all of the port bits of an SX28, you could drive any one of 380 individual LEDs.
Cheers,
Peter (pjv)
In actuality I would like to be able to control 100 or more LEDs.· I would like to control each one separately and yes I would like to be able to change the intensity of the light!· I am trying to create a board display that would act similar to a banner board and/or a bright-lite game!· Plus be able to scroll through each light and turn it on or off to make pictures on the board display!
How is it possible to control each one of the individual 100+ LEDS with one SX28?
Please explain?
Kevin
Education And Experience Teaches Knowledge Not Arrogance ! (Unknown)
The Only Stupid Question Is The One Not Asked ! (Unknown, of coarse this is something that i would say)
Do Not Burn The Bridge That Has Brought You Forth You May·Need To Journey Back ! (Chinese)
Post Edited (DigitalDj) : 5/4/2006 11:01:28 PM GMT
Please tell me more!
Joe
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/4101
I·will be·using this circuit and a SX28 to control 2 grids of 64 RGB leds. I attached a photo link for you to see my prototype. These will go in my jukebox project which is pictured with my post.
http://pg.photos.yahoo.com/ph/adigitaldj1@sbcglobal.net/album?.dir=4ea5scd&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos
Post Edited (DigitalDj) : 5/5/2006 12:50:23 AM GMT
1+1=10
Post Edited (Paul Baker) : 5/5/2006 2:01:43 AM GMT
I will keep an eye out on your project but, "about the size of a grain of sea salt" this is too much for me!
Thanks for the info!
Anyone else worked with multiple decoders in a sequence programmed by an SX28 chip to control 100+ LED's??? If so I would love to hear from you!!
Joe
Here's a pic of the board:
The seperate top and bottom layers are in attachments in this thread: http://forums.parallax.com/showthread.php?p=576794
1+1=10
Post Edited (Paul Baker) : 5/5/2006 6:13:45 PM GMT
