Basic relay question
I have a relay that is rated for 30Amps @ 120VAC. (It opperates at 12VDC but the contacts are rated @30 amp 120vac)
I would like to use it to drive a 12 AMP 20VDC load. Would that work OK?
Thanks for any insight!!!
Post Edited (wolff) : 5/4/2006 9:53:17 PM GMT
Don't visit my new website...
If it is a solid-state, on the other hand...
A DC arc has to be extinguished simply by the speed and distance the contacts separate as they open. A resistive load arc ( light bulb, heater, etc) is very easy to extinguish. A highly inductive load ( coil, motor, etc) is hard to extinguish so it is common to derate contacts depending on the type of load.
Having said all that, a 12A load on a 30A contact and at a lower than rated voltage will probably be OK. If your relay has multiple contacts, put two in series to increase the arc extinguishing capability.
At least, I haven't blown one up yet...
