Can this be true?
I started to read the Propeller documentation and was immediately surprised to read that the I/O pins can be independent of the hub.
Does this mean that if I wish to do so·I can have one COG just handle an assigned·set of I/O pins and remain completely independent of the other COGs?
It seems quite strange, but I can see where it could be sometimes useful.
·· That is correct...The individual Cogs can have direct access to the I/O lines.· The Hub controls access to the shared memory.
Chris Savage
Parallax Tech Support
csavage@parallax.com
I suppose that might not be true parallel. But it is a lot of power in one little package.
I just must get my breadboarded version up and running ASAP, even without the EEPROM and MAX3232.
Jon Williams
