Before the fun begins
I think this the time for Chip to give us guidelines of how to deal with the +5 modules when connected to the propeller.
I have some modules rated at 3.3 volts, some rated at 3.3 V but tolerant to 5V, some just plain 5V.
What procedure or protection do you recommend?.
I do not want to blow any Propeller and void the warranty.
Jon Williams
This is what I am thinking of doing.
The TTL Rx between the MAX232 and the PROP would use a 1000 ohm resistor, right?
The TTL Tx between the MAX232 and the PROP would use nothing, okay?
The 3rd line which is a reset seems like I could leave it unchanged.
·· If you have a few 2N3904 NPN transistors laying around, a 2N3906 PNP and a few resistors you can make your own serial interface per the schematic posted elsewhere in this forum.
Chris Savage
Parallax Tech Support
csavage@parallax.com
That would be in the PropStick's thread.
I was thinking that the voltages might be too low. But, it is a start.
Mouser has backordered my purchase of MAX3232s in DIP for 5 weeks.
I can only get SMDs from my alternative.
So, it looks like the transistors are a bit simpler than a double power supply.
Post Edited (Kramer) : 5/2/2006 3:40:36 PM GMT
Propeller Serial Programming Adapter - Testing
http://forums.parallax.com/showthread.php?p=581171
Beau Schwabe
IC Layout Engineer
Jon Williams
