newbee question, parallel out?
Howdy, folks,
I'm a retired embeded systems programmer.· I bought a basic stamp development system
just to have something to fool around with when I get tired of working on other things.
Now I find that I have a job...
A friend of a friend is writing a PhD thesis on elephant communications and wants me
to make a low frequency audio tone generator.· No problem in Pbasic if I stick to square
waves, but I'd like to reduce the high frequency harmonics.· So I thought about driving
an R2R resistor network D/A converter.· But then, looking through the Pbasic manual,
I couldn't find any way to shove a nibble or a byte at the I/O pins in one statement.
Can this be done by writing into RAM?· Should I consider PWM?· Or should I just go
with square waves and a big cap to suck out the higher frequencies?
BTW..· I'd kinda like the frequency to be good to within 10 Hz or so..
Any guidance would be appreciated.
tnx,
--del
tnx,
--del
' {$STAMP BS2} ' {$PBASIC 2.5} DIRS = $00ff ' P15-P08 = INs. P7-P0 = OUTs OUTL = %00000000 ' all outputs to 0 parallel VAR byte FOR parallel = 0 TO 255 ' this will rifle through $00-FF OUTL = parallel next parallel = %11110000 ' here's $F0 OUTL = parallel parallel = %00001111 ' here's $0F OUTL = parallel ENDPost Edited (PJ Allen) : 4/30/2006 1:37:55 AM GMT
Now I get the syntax...
You helped me RTFM..
--del
Which end do end-users use?
