Free PDF printer test mentioned in (May 2006) Nuts&Volts magazine.
Beau Schwabe
Bruce Bates,
This might be something along the lines of what you were looking for...
Nuts and Volts magazine is offering a free download of PrimoPDF
www.nutsvolts.com/toc_Pages/TOC_Related_Info/0605/qa.php
Simply run the program, and it will install as a PDF printer.
Now, any application that supports a printer can create a PDF file when you select
the "Primo PDF printer" to print to.
I tried it, and the only issue that I see that you might need to watch out for is word
wrapping. You have the option to turn off word wraps, but it truncates the right most
text if you do so.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 4/29/2006 1:17:45 AM GMT
text if you do so.
Beau Schwabe
IC Layout Engineer
Thanks for that. I'll give it a shot. Pain in the neck to have to re-create the PDF every time, but the price is right! Free is GOOD!
Bruce Bates
<!--StartFragment -->
OS-X: because making Unix user-friendly was easier than debugging Windows
Before you gentlemen get a sprained arm from patting yourselves on the back too much, this is also true since Windows 3.0 many years ago. The real problem (since this thread was instigated by me), is MANIPULATING (add, modify, delete) a PDF file (per se) without having to recreate the whole darned thing all the time, which obviously necessitates that you keep it in some non-PDF source format.
Perhaps the problem is that I just don't understand the theory of PDF input, since I've never seen or used any Adobe (or other) products which can perform ALL functions which might be available for PDF files.
Bruce Bates
www.answers.com/Adobe%20Acrobat
The bottom line is Adobe Acrobat was designed to create text and images that are viewable on a large number of computer platforms (thru Adobe's free Acrobat Reader) but keep the original content encrypted so it can't be modified. If you purchase Adobe Acrobat (there are several versions starting around $300) then you can create Acrobat documents that can be modified - such as entering text/numbers in certain fields.
I don't think you understood my comment about OSX - Apple includes Display Postscript in their operating system so ANY OSX application can create an Acorbat file - including a screen capture. This flexible Acrobat output was never included in any version of Windows.
Not to create a deeper trench between Windows or Mac users, I wonder why I haven't seen this ability to create
PDF files from a Linux system or a true UNIX system without using licensed Adobe software that lets you do so,
since OSX is so close to both of those platforms
Beau Schwabe
IC Layout Engineer
It just encapsulates GS for use as a printer driver under Windows. It's produced
by the same people that sell a commercial version of Ghostscript, Aladdin.
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
