Looking for tiny keyboard
Hi everybody.
I'm thinking of putting together a little computer that will fit in my pocket, and have located everything I need except a suitable keyboard.
What I want is a keyboard like the one on a Sidekick or Blackberry that will plug into a USB or PS/2 port.
Does anyone know where I might find something like that?
I wonder if this wire is hot...
Foldup:
http://www.amazon.com/gp/product/B00006HYQG/ref=nosim/002-9758537-4785652?n=172282
Non-Foldup:
http://www.cdw.com/shop/products/default.aspx?edc=542119
http://www.compusa.com/products/product_info.asp?ref=CNET&pfp=CNET&product_code=50246255&cm_ven=CNET&cm_cat=&cm_pla=&cm_ite=feed
http://www.compusa.com/products/product_info.asp?ref=CNET&pfp=CNET&product_code=50233527&cm_ven=CNET&cm_cat=&cm_pla=&cm_ite=feed
1+1=10
I followed your links and found this:
geek.pricegrabber.com/search_getprod.php/masterid=513143
It's only $7 and looks small enough.
What kind of connector is that though?
It says that it will work with a handspring PDA.
Do you think I could chop it off an wire up a PS/2 plug?
1+1=10
www.mp3car.com/store/product_info.php?products_id=104
Or if you're really cheap and/or adventerous - here's a Palm PDA keyboard from Computer Geeks for $0.89
www.geeks.com/details.asp?invtid=TKB160P&cat=MOU
The seems the easiest to hack. You could even use it with a BasicStamp if you can decode the serial and keycodes.
I really don't think there is anything generic like the Blackberry or Treo. The alphanumeric keyboards that size tend to be part of an entire system.
