The Propeller video Demo ?
I would like to see some video clips of the Propeller video.· ???
Also, where can I find the little video display shown on the
cover of April 06 Nuts And Volts Magazine ???
How much is it ???
Ibsen
" It's nice to be important, but
·· more important to be nice... "
How much is it ???
Ibsen
The number in the upper left hand corner counts from 0 to 9, The ring of stars in the upper right hand corner rotate around the ring and rotate around thier individual center points as they rotate. The version I have has a circle of scotty dog sprites (like the Win 3.1 background) rotating around. The blue cross in the center expands towards you, then starts small again. The blue triangles bounce around in strobe fashion, like some screen savers do (I remember Sun's screen saver does this). And when you press the mouse button, snowballs are thrown from the cross in a galaxy spiral's motion.
1+1=10
Post Edited (Paul Baker) : 4/25/2006 6:24:06 PM GMT
Parallax is stocking the 2.5" NTSC/Pal display. In fact, they're currently being shipped over via air with the rest coming by surface. They'll be in stock shortly - within a week. You can find these on eBay for $35-50, but there's always another $30 of shipping from Hong Kong to get them to you. We'll be selling them at somewhere between $50 and $79, to be determined over the next week. I need to talk to Lauren, Product Marketing Manager to get this squared away.
We've looked at a number of displays from different Asian suppliers and chose this model from Pustom.·Even at $79, I think it's a tremendous value compared to a $40 2x16 Serial LCD.
Sincerely,
Stan Dobrowski
directly to the video output of the Propeller Demo Board. The video rendering to MPEG does NOT do this
demo justice.
Beau Schwabe
IC Layout Engineer
1+1=10
WOW I think it is very impressive.
That is quite complex graphics and
smooth to !!!
I can't wait to get started with the Propeller...
Ibsen
Ibsen
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 4/26/2006 4:22:41 PM GMT
Ibsen
Beau Schwabe
IC Layout Engineer
http://forums.parallax.com/showthread.php?p=573833
I have a couple of nice projects planned for my car ;-)
Ibsen
Ibsen
Beau Schwabe
IC Layout Engineer
I assume the frame rate changes with video resolution ???
Ibsen
This is a little confusing because frame rate is being used for two different things. The prepeller frame rate of 30Hz is the how often the image is sent to the TV to repaint the phosphor screen. Usually this is called refresh rate on PC monitors (typically 60Hz to 80Hz). In PC terminology frame rate usually refers to how often a new image is generated within the computer, and higher resoluiton is slower because it requires more computation. The PC monitor refresh rate is independent of the software update rate
I think you have to use 30Hz for NTSC because TV's can't adjust to different rates wheras PC monitors can sense the refresh rate and adjust to match the video card.
(heavily edited, hopefully more coherent.)
Post Edited (Russ Miller) : 4/27/2006 11:34:36 PM GMT
What is in my head does not always make it to the keyboard ;-)
Ibsen
