The Propeller video Demo ? — Parallax Forums
IbsenIbsen Posts: 68
edited 2006-04-28 14:55 in Propeller 1
I would like to see some video clips of the Propeller video.· ???
Also, where can I find the little video display shown on the
cover of April 06 Nuts And Volts Magazine ???
How much is it ???
Ibsen
" It's nice to be important, but
·· more important to be nice... "
    edited 2006-04-25 18:07
    I can't provide a video, but I can describe the motion in the commonly seen demo:
    The number in the upper left hand corner counts from 0 to 9, The ring of stars in the upper right hand corner rotate around the ring and rotate around thier individual center points as they rotate. The version I have has a circle of scotty dog sprites (like the Win 3.1 background) rotating around. The blue cross in the center expands towards you, then starts small again. The blue triangles bounce around in strobe fashion, like some screen savers do (I remember Sun's screen saver does this). And when you press the mouse button, snowballs are thrown from the cross in a galaxy spiral's motion.
    1+1=10
    Post Edited (Paul Baker) : 4/25/2006 6:24:06 PM GMT
  • Ken GraceyKen Gracey Posts: 7,418
    edited 2006-04-25 18:15
    Dear Ibsen,
    Parallax is stocking the 2.5" NTSC/Pal display. In fact, they're currently being shipped over via air with the rest coming by surface. They'll be in stock shortly - within a week. You can find these on eBay for $35-50, but there's always another $30 of shipping from Hong Kong to get them to you. We'll be selling them at somewhere between $50 and $79, to be determined over the next week. I need to talk to Lauren, Product Marketing Manager to get this squared away.
    We've looked at a number of displays from different Asian suppliers and chose this model from Pustom.·Even at $79, I think it's a tremendous value compared to a $40 2x16 Serial LCD.
    Sincerely,
  • Stan671Stan671 Posts: 103
    edited 2006-04-26 03:05
    I have used one of these Pustom LCD's before and they are very nice. It worked perfectly right up to the point where I accidently smoked it. Ahh ... the perils of loose wire. <grin>
    Stan Dobrowski
    edited 2006-04-26 04:18
    Here is a captured video of the Propeller demo I just did using a Belkin USB Audio Video adapter connected
    directly to the video output of the Propeller Demo Board. The video rendering to MPEG does NOT do this
    demo justice.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-04-26 13:41
    Oh yeah I forgot I have an S-Video to MPEG renderer Ive used to transfer VHS to DVD, I can get you a high quality version tonight.
    1+1=10
  • IbsenIbsen Posts: 68
    edited 2006-04-26 16:02
    Beau, thank you for the video...
    WOW I think it is very impressive.
    That is quite complex graphics and
    smooth to !!!
    I can't wait to get started with the Propeller...
    Ibsen
    edited 2006-04-26 16:04
    What is the resolution of the video output of this demo ???
    Ibsen
    edited 2006-04-26 16:12
    The video was captured at 320x240 ... Attached·is a still image at 320x240
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 4/26/2006 4:22:41 PM GMT
    edited 2006-04-26 16:16
    OK, but what is the video resolution output from the Propeller ???
    Ibsen
    edited 2006-04-26 16:48
    The TV mode resolution from the Propeller·is·256 x 192
    Beau Schwabe
    IC Layout Engineer
  • JT CookJT Cook Posts: 487
    edited 2006-04-27 02:20
    Also the Hydra people are doing some cool stuff with video as well. Check out the demo real that was posted a while back of the upcoming kit.
    http://forums.parallax.com/showthread.php?p=573833
    edited 2006-04-27 03:06
    That is very cool !!!
    I have a couple of nice projects planned for my car ;-)
    Ibsen
    edited 2006-04-27 20:08
    What is the frame rate at 256 x 192 ???
    Ibsen
    edited 2006-04-27 20:20
    Standard NTSC 30fps ... I'm not sure I understand your question?
    Beau Schwabe
    IC Layout Engineer
    edited 2006-04-27 21:58
    You anvsered my question...
    I assume the frame rate changes with video resolution ???
    Ibsen
  • Russ MillerRuss Miller Posts: 25
    edited 2006-04-27 22:27
    Ibsen said...
    This is a little confusing because frame rate is being used for two different things. The prepeller frame rate of 30Hz is the how often the image is sent to the TV to repaint the phosphor screen. Usually this is called refresh rate on PC monitors (typically 60Hz to 80Hz). In PC terminology frame rate usually refers to how often a new image is generated within the computer, and higher resoluiton is slower because it requires more computation. The PC monitor refresh rate is independent of the software update rate
    I think you have to use 30Hz for NTSC because TV's can't adjust to different rates wheras PC monitors can sense the refresh rate and adjust to match the video card.
    (heavily edited, hopefully more coherent.)
    Post Edited (Russ Miller) : 4/27/2006 11:34:36 PM GMT
    Russ, you are correct...
    What is in my head does not always make it to the keyboard ;-)
    Ibsen
