Multiple led drivers
Hello....
I am driving 4x 8 digit led displays using 4x Max7219 IC's.
I also have a BS1302 chip keeping time for me.
My question is....· any ideas on how to cut down on the I/O lines required?
The above basically uses all 15 of my I/O lines.
3 for each Max and 3 for the BS1302.
I have switched a couple of the displays over to the aux I/O side·on my BS2P40.
Two·of the display's·only update occasionally and don't need to be in the main loop.
That has freed up 6, but I really need to free as many as possible on the Main I/O side.
Speaking of freeing I/O lines... any ideas on minimal I/O, 16·button matrix keyboard connections?
Found a few circuits using Pulsin and time based inputs, but they seem a bit hit and miss.
Suggestions!
Thanks, Steve
Suggestions!
Thanks, Steve
Jon Williams
I will look for a circuit diagram, as I assume you would loop them using the DOUT pin on the Max's
Thanks for your time.
Steve
I have looped all the clock connections
I then fed the first Max on pin 1 with the data line, then chained them in a line linking pin 28 of the Max (DOUT) to the next Max's pin 1 (DIN)
The load lines are now all linked together as well.
It appears to have gone completely screwy for some reason,
The displays no longer show the correct time etc
Another late night ahead!
Post Edited (Steve2381) : 4/25/2006 11:08:36 PM GMT
