Suggestion — Parallax Forums
Suggestion
A.C. fishingA.C. fishing Posts: 262
edited 2006-04-25 18:15 in Robotics
Hmm... Could you moke the Boe-Bot battery packs a bit stronger? I've already gone through 4. The wires keep breaking off the pack, and when I try and solder them back on to the pack, the close plastic area melts.
ACfiishing
Somebody said...
-Never Underestimate the power of human stupidity.
    edited 2006-04-25 00:55
    Thread moved to "Robotics" from "Support for this Forum"
    Jon Williams
    edited 2006-04-25 02:18
    If the plastic is melting then you are applying heat too long.· It's not easy to solder on something mounted to plastic, but it can be done.· At the same time you could request a replacement from our Tech Support Dept.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • Steve JoblinSteve Joblin Posts: 784
    Many electronic warehouses (digi-key, mouser, etc.) carry a nice line of all aluminum battery holders... check out
    http://www.digikey.com/scripts/DkSearch/dksus.dll?KeywordSearch
