SXKey IDE prompting on file version
I've been working with an SX/B program which I have stored on a flash drive.· I have 2 files open in the IDE and when I switch between them
or if I alt-tab from the IDE to another program and then back to the IDE it (about 80% of the time) will prompt me that a new version of the
file exists on the drive, do I want to load the newer version from disk. It also has done this to me when compiling, programming and when running SXSim. I do not have explorer open, nor does any other program have files open on that drive.
It will do this even right after I click SAVE (or save->compile or save->program)
No other programs have modified that file and since I just saved it, the version on disk·is the latest, but it still prompts me that a newer
version is available on disk.
any ideas? I've looked at the date/time stamp on the file and don't see any huge difference or discrepancy that would explain it.
paul...
paul...
That happens to me sometimes too. You cannot get back to IDE unless you reload the file.
I haven't figured out why it happens either.
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available·for only·$49.95·www.sxvm.com
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
Ray
Thanks, PeterM
<Edit: I am not using a USB·flash, just the standard setup.>
Ray
Post Edited (Rsadeika) : 4/26/2006 1:22:34 PM GMT
I'm using 3.10 also.
I should note that my files are on a USB flash drive also. Maybe there is something funny about the way they work (timestamp?) that is confusing the IDE.
Bean.
today after having saved the file and not having modified it either, I got prompted if I wanted to load the newer version from disk. In the IDE file list, there was no asterix next to the file name either. I had a few times when I saved the file and all I had to do was switch back and forth between the 2 open files in the IDE and each time it would prompt me about the newer file.
(I too have 3.1)
Here's what I believe is going on:
I think that when the file is saved, the IDE gets the timestamp from the OS right after the save. The problem is that the info has not actually been written to the disk but is either cached somewhere or pending completion in the USB drive. The result is that the timestamp it receives and stores internally is actually the timestamp of the original file which didn't get overwritten yet. Meanwhile, you work happily and at some point switch to another program. When you come back, the IDE gets the timestamp from the OS (which is now accurate and reflects the time of the completed write), compares it to the bogus value returned earlier by the OS, and can only conclude that there is a new version on disk.
I'll see what is going on and try and get it fixed.
hanks, PeterM
just checked my USB drive.. I have it set for "optimize for quick removal" which turns write cacheing off. It is also USB 2.0 so shouldn't be too slow or anything, especially with the relatively small file sizes. If there's something I can do to help you test this, let me know.
putting my code on an USB drive is really handy since I work on this stuff during lunch and on breaks and I can then easily take the stuff home with me.
Paul...
Same for me. Let me know if there is anything to want tested.
Bean.
COMING SOON "SD DATA LOGGER" www.sddatalogger.com
I appreciate this being brought to my attention so I could address it. I also appreciate the key detail that made the fix easy to locate which was that the files were being written to a USB flash drive. In bug reports, the more details given, the easier it is to find. If no one had mentioned that detail, I would have tested it on my hard drive and reported that I was unable to replicate the bug.
When CCS, Parallax and I get all the C compiler issues sorted and release a new version of the IDE (we're working on it!) this bug fix will come along for the ride.
Thanks, PeterM
Not to seem ungrateful, but has the problem with WATCHing bit variables been fixed ? If I remember right it works if the bit is in position 0, but it doesn't if it's in position 1-7.
Bean.
I can't remember off the top of ym head. I believe I fixed it in my internal version, but I have to verify this to be sure.
Thanks, PeterM
