RS232 output from a BS2 is different then RS232 from a computer??? PLEASE HELP!
Ok so most of my projects that involve RS232 ASCII communications work great, but IV been beating my head agents the desk on this project.
What I have is a Yaskawa linier stage controller that is controlled by RS232 ASCII. When I connect it to the Com port on my computer and type in the commands through HyperTerminal it works fine. But when I connect it to the APPmod RS232 port on the BS2 and send the exact same code, it doesn’t respond. I also plugged the BS2's port into my computer and I see the ASCII code as it’s supposed to be. is there a difference in the signal / noise. it is on a transformer power supply and the ocilliscope says its a little noisey when improperly grounded.·but yea Iv also tried tuneing the baud rates of the BS2·from 70 -to- 90 but i think 84 is the best and i cant change the baud on the Yaskawa, well... i can go up in speed with it but 9600 is as low as it goes. man this is bugging the heck outa me!
Code Iv tried:
SEROUT 2, 84, [noparse]/noparse][color=red]"SH"[/color], [color=purple]CR[/color
"and/or"
SEROUT 2, 84, [noparse]/noparse][color=red]"SH"[/color], [color=black]13[/color
and iv tried
SEROUT 2, 84,· [noparse]/noparse] [color=red]"S"[/color
PAUSE 100
SEROUT 2, 84, [noparse]/noparse][color=red]"H"[/color
PAUSE 100
SEROUT 2, 84, [noparse]/noparse][color=purple]CR[/color
nothing seems to work!!!!!!!!!
Please Help, i dont want to have to buy a whole nother computer just for this reason
Post Edited (Grant_O) : 4/24/2006 11:53:41 PM GMT
Code Iv tried:
"and/or"
and iv tried
PAUSE 100
PAUSE 100
Another think, the Yaskawa to the PC is via a serial extension, right (male to female), right?
In that event, using the DCE AppMod, you'll need a Null Terminal cable (with pin2 on A going to pin3 on B, pin3 on A going to pin 2 on B.)· Yes?
[noparse][[/noparse] A Null Modem is a female-to-female, swapped as above, a Null Terminal is a male-to-male cable as above.· Others may not dig the difference.· They'll call it a "male-to-male null modem." ]
So, what's the story, morning glory?
Post Edited (PJ Allen) : 4/25/2006 12:20:17 AM GMT
i was thinking though.... i used the default settings in Hyperterminal minus the hardware flow control. but is the serial output of the Bs2 truly:
9600 baud
8 data bits
no parity
1 stop bits
no flow control?
Jon Williams
Yea i guess i should have used a constant for the baud rate. But you say to use "inverted mode". What is that exactly? And how is it different from what im doing?
thanks.
Jon Williams
Chris Savage
Parallax Tech Support
csavage@parallax.com
Jon Williams
