Need help with Strings and SERIN, Maybe even a few lines of sample code???
Hey everyone.
I am trying to·use SERIN·to gather certian string data and match it to Conditional statements.
the strings are "Hello" and "Goodbye".
if the string = "Hello" then the BS2 will go to the lable, Hello:
if·the string = "Goodbye" then the BS2 will go to the lable, Goodbye:
If its something else the BS2 will goto the lable, TryAgain:
I have been trying to figure how to make the BS2 understand these Strings but·I havnt been secessful yet. and the help files dont describe it much. Please help!!!
Thanks.
Thanks.
Jon Williams
String1 VAR BYTE(10)
MAIN:
GOSUB ClearString
GOSUB GetString
Done = 0
IF String1(0) <> "H" THEN TryNext
IF String1(1) <> "e" THEN TryNext
IF String1(2) <> "l" THEN TryNext
IF String1(3) <> "l" THEN TryNext
IF String1(4) <> "o" THEN TryNext
GOTO Hello
TryNext:
IF String1(0) <> "G" THEN EndTries
IF String1(1) <> "o" THEN EndTries
EndTries:
GOTO MAIN
' etcetera. Well, I hope you get the idea.
' You COULD store the "Hello" and "Goodbye" check strings
' in a DATA statement, and condense the above code
GOTO MAIN
' ************** Subroutines ********************
ClearString:
FOR I = 0 TO 9
String1(I) = 0
NEXT
RETURN
GetString:
SERIN 16, 16384, [noparse][[/noparse]STR String1]
RETURN
Jon Williams
That program worked very well with my application.
But hey Mr. Williams,
I'm a little curious about your byte-code scheme. Do you have any information or resources about it? Because variable space is very important as well!
String1 VAR BYTE
MAIN:
GOSUB ClearString
GOSUB GetString
IF String1 <> "H" THEN TryNext
GOTO Hello
TryNext:
IF String1 <> "G" THEN EndTries
GOTO Goodbye
EndTries:
GOTO MAIN
Hello:
' ... Whatever
GOTO MAIN
Goodbye:
'... More stuff
GOTO MAIN
ClearString:
String1 = 0
RETURN
GetString:
SERIN 16, 16384, [noparse][[/noparse]STR String1] ' Where String1 will be "H" for 'Hello', or "G" for 'Goodbye'
RETURN
' Jon's solution used "bytecodes" of $C0 or $C1 for the input characters,
' but you can just as easily use single type-able characters of "H" or "G".
' I believe you'll have to send the character with a 'linefeed' character after it,
' to tell the BS2 run-time that the "string" is done.
But hey thanks for all the help!
I think I have enough now to get started.
