Ping BOE Jumper — Parallax Forums
Ping BOE Jumper
MaltedfalconMaltedfalcon Posts: 3
edited 2006-04-19 14:17 in Robotics
The Ping instructions say use the Boe jumper set to VDD or you can damage the Ping Unit.
The BOE robotiscs Book says set the jumper to Vin to use the servos.
What if you want to use the servos and the Ping?
And Where can I find a succint explanation of the jumper and the difference between VDD and Vin
If you are just using the 6V battery pack does it actually make a difference what it is set to?
Matt Sparks
Maltedfalcon
    edited 2006-04-19 02:08
    Matt,
    ·· Vin = whatever voltage you have going into the BOE-Bot.· Normally that is around 6V.· Now Vdd is always 5V, which is what the PING))) requires, and what the servos will work just fine with.· Basically if you didn't need 5V from the Servo Headers you could use the Vin setting and get slightly more juice for your servos.· But since you want to connect the PING))) there you use Vdd and everybody gets 5V and is happy.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2006-04-19 04:16
    Like Chris said, you could simply use breadboard area and a three pin male-male header.
    Ryan
    Ryan Clarke
    RClarke@Parallax.com
  • MaltedfalconMaltedfalcon Posts: 3
    Ah The light dawns, thanks
    I hooked the ping up through the breadboard.
    I will use the socket now and Vdd
    Maltedfalcon
