javelin on professional devel board
I cant seem establish a connection to the javelin through the usb port on the PDB.· it works with a BS2p and it works· when i use the usb to serial adapter and 9 pin programming port (meaning the jide will detect it..still get error 6 when trying to load program). I changed the latency down to one for that port and i have downloaded and reinstalled the driver.·· any ideas?
Could not open the serial port %s: The serial port could not be opened.
[font=Arial,Arial size=2]Make the serial port is not already in use by another program.
[/font]
So it looks your usb driver keeps the port open. Close down all applications that use that
port, perhaps even reset pc, then try again.
But first check if your com port is listed in the IDE.
In the IDE, go to Projects->Global options
Tab Debugger, then edit port list (click ... next to droplist)
Then try it, if it does not work, try resetting the pc.
regards peter
The poster there hoped it would not be the FTDI chip used on the PDB that
caused the errors. I can't seem to find that thread now, but I am positive it
was the SX forum, or the Sandbox.
But as I understand you, you can program the javelin using a seperate usb2ser cable
or the serial cable, right?
regards peter
http://forums.parallax.com/showthread.php?p=564332
regards peter
·· The PDB does support the Javelin through the USB Port for programming.· The Javelin IDE, however, does not support COM Ports above 4, as I recall.· What COM Port was assigned to the USB interface?· If it was higher, try setting to a COM Port below 5.
Chris Savage
Parallax Tech Support
csavage@parallax.com
