Looking for drive system suggestions
Ok, I have a layout for a robot that I am currently working on, and I have a few questions regarding the drive system. I have attached a pic illustrating the layout of the motors. The motors and shafts are pictured in green, and the metal body in white. The motors need to drive a wheel attached to their shaft, plus a wheel on the shafts at the opposite ends. The obvious answers would be a belt or chain, but thats where the suggestions come in. I need to know what a better solution would be: A timing belt that drives a large pulley on each shaft so that it works like a track, thus eliminating the need for other wheels, or should I have a wheel on each shaft and have a smaller timing pulley next to each wheel with a belt driving it, or the same thing with sprocket and chain instead?
Also, I would like to have a little backlash as possible so that all four wheels turn and accellerate at the same speed and time.
Justin W
Justin W
Should you decide to use wheels, I think timing belts would be much better than chains. Less noise, more efficient, easier to work with, etc. If you use the right sized belts, the wheels should turn together perfectly. Here is a very handy calculator to figure out the belt length/pulley diameter/distance needed:
http://www.sdp-si.com/Cd/default.htm
I have no idea if something like that actually exists and how much it is, but if anyone knows, that would be great.
nelnick.com/nelnickrobotics/product_info.php?cPath=25_26&products_id=279&osCsid=6b507897dc910bd959ff14dafd661223
