3.3V I2C from BS2px
I'm trying to control a 3.3V I2C device from BS2px and i have a few questions.
Only need to use I2COUT command.
Can i use a couple of resistors to make a voltage divider to reduce the 5V SDA and SCL lines to 3.3V and would i put the pull-up resistors on the 5V side of the divider?
Is the max pin current draw the same as normal when using I2C commands?
Cheers.
Cheers.
The Art of Electronics has nearly a whole chapter explaining how to match up devices of different voltages and different generations of productions.
It would help if you could specifically mention what device you want to use. It might even work at 5volts without any resistor.
Jon Williams
