Determining maximum RPM for a stepper motor?
I have a project that I plan to use a stepper motor to operate. The motor needs to spin at about 3k-4k RPM. When I started to research stepper motors, I noticed that unlike DC motors, they do not list a Maximum RPM. Is max RPM derivable by examining the typical specs included for a particular motor?
Most specs seem to indicate the degree per step, coil voltage / amperage and coil disposition (i.e. unipolar/bipolar) physical charictaeristics etc. But I haven't seen any with RPM ratings..?
Vern
PS: FWIW, I do plan to operate this device with the Basic stamp and a serial stepper motor controller of some type.
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
