Rapid fire
I want to be able to turn on and off an electric device rather fast, .25-5 seconds.
Im looking for somethign along the lines of a relay that once powered will turn on and off realy quick, almost like a strob light.
Any sugestions?
Any sugestions?
pwssr's idea is interesting -- sort of a Gattling gun effect
im looking to have a solenoid fire quickly, its sort of hammering a nail into a board.
Tim
And as to the basic stamp idea, I was forced to throw that one out due to its price.
...actuly my original idea was to use a stamp and multiple solinoids, pull out the mechanisim that holds the pushing peice in the solinoid and line them up. then i could time the diffrent solinoids and the one rod would fire throu all of them, sort of a rail gun... but that was also thrown out do to pricing.. lol
http://home.cogeco.ca/~rpaisley4/LM555.html
Take a look at the 555 calculator link at number three to calculate the resistor and capacitor values to give you the speed you want.· You should be able to put your circuit together for only a couple of dollars... 20-80 cents for the 555 timer, pennies for the resistors and capacitors, then a MOSFET transistor on the output of the timer, and your other misc. stuff like the push button.
Tim
1 more question, at no point does it comment on the voltage of the capacitors, only the charge... does it matteR?
Tim
Except for Tantalum capacitors used as supply decouplers, where twice the supply voltage is a reasonable starting point, especially if they can ever see sharp voltage rises (power turned on by a switch / plug, rather than a voltage regulator or switch mode power supply, where the voltage rises (relatively) slowly.)
Steve
Tim
