Using a SX18 source code with a SX28?
I got a source code written for a SX18.
Might seem as a silly question..
Is it possible to transfer the same code to a SX28 chip by changing the Device configuration in the code·to SX28?·
appreciate any feedback!
Since the SX18 doesn't have the port C IO pins, it allows the programmer to use adddress 7 for one additional byte of global memory, which is used by the SX28 for port control.
So just make sure that in the SX18 code, address 7 isn't used as general purpose RAM.
I think that aside from that, you should be fine.
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
