where can I get strong motors affordably?
I am looking for a pair (meaning two of the same, or one left hand one right hand) of motors with similar specs to these: banebots.com/osc/product_info.php?products_id=232. I like the RPM and torque of those, and I may order them, but before I do, I want to check up on a few things. Firstly, does anyone know of similar motors for a better price? I consider the price of those pretty good [noparse][[/noparse]$40 ea.], but if I can go cheaper, I would like to. Secondly, If I give my robot 6" wheels and those motors, what would be an acceptable weight for the robot if I wanted it to have a good amout of power? (it should be able to handle a mowed lawn, gravel, and some light woods). Another thing is, those motors seem impossibly small for their torque output, I mean that's over 1/2 HP! Is that believable? The stall current draw also concerns me. how can I possibly drive those with the stall current almose 40A? Does the HB-25 have over-current protection?
Thank you,
Justin W
Post Edited (Whelzorn) : 4/2/2006 9:43:00 PM GMT
Thank you,
Justin W
PAR
Post Edited (Catharsis) : 4/2/2006 11:00:54 PM GMT
Has anyone else used the motors from this company? I've never heard of them before, but they look pretty good. I'd just like to get someone elses opinion before I go for it.
Supposedly these motors hold up fine in fighting robots, so it's not like they are cheap or will fall apart. I think those(or maybe another size/ratio) would probably be your best bet for any type of robot.
BTW, for the wheel size/weight question, this calculator should help:
http://www.architeuthis-dux.net/tcr-home.asp
Go to Tools>Torque / AH Calculator
It has the motors you linked to.
http://www.allelectronics.com/cgi-bin/category/400400/DC_Gear_Motors.html· (1st, 2nd and 5th motors)
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM01MTR4488&Category_Code=DCGEARHEAD
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM03MTR4638&Category_Code=DCGEARHEAD
6+6=10 (Long live the duodecimal system)
http://search.ebay.com/_W0QQfgtpZ1QQfrppZ25QQsassZpbasic1
Chris Savage
Parallax Tech Support
csavage@parallax.com
So does anyone know what I should use to drive these? does my driver have to be able to supply 40A? should I just use relays?
Thanks everyone
http://www.parallax.com/detail.asp?product_id=29144
Chris Savage
You're statement about not being able to stall these may be a little strong. Unless the device can push over any wall, chances are that it WILL encounter a stall condition at some point.
Never say never...
Truly Understand the Fundamentals and the Path will be so much easier...
·· Not taking sides here, but in my experience many wheel drive systems "slip" before they stall the drive motor.· It really depends on the drive-train and the surfaces it will be on.· If you pull a car up to a brick wall and then start accellerating, it will usually start spinning the tires after awhile.· Now on a standard that may vary depending on release speed of the clutch and RPM of the motor, but the point is it would have to be stress tested under normal operating conditions to gauge that.· Nobody can know without actually trying it, even the builder.
Chris Savage
I agree with you as it has been my experience, as well. I guess that I just have let too much smoke out to not "assume the worst possible condition" and plan for that. (not to mention that even if it doesn't stall, the current still climbs above "rove")
"Nothing beats building it so that it flies as it normally would...until the bird hits the engine..."
You bring up a very valid point. It is always best to build for the worst possible conditions. But in this case with 103 lb/ft of torque, even on a robot weighing 30 lbs, I can't see these motors coming close to stalling. As noted earlier in the thread, using fuses would be a good option.
and
http://www.edn.com/contents/images/92503di.pdf#page=4
you would meld the hbridge aspect of the second with the microcontroller control of the first.
The idea is to measure the voltage across a very small value resistor (sense resistor)·to determine current flowing through it.
