Tv.spin
Mike CookMike Cook Posts: 829
edited 2006-04-03 - 14:43:59 in Propeller 1
Is it possible to get a schematic for the TV.SPIN object?
"OEM NMEA GPS Module" Now available on ebay for only $17.49
http://www.allsurplus.net/Axiom/
http://www.allsurplus.net/CNC/
    edited 2006-04-01 - 17:59:20
    Found this post from Jon:
    For color composite video out you need three pins, three resistors, and an RCA jack:
      A12 -----[noparse][[/noparse] 1.1k ]-----*-----> composite out
      A13 -----[noparse][[/noparse] 560  ]-----*
      A14 -----[noparse][[/noparse] 270  ]-----+
    So that answers the initial question. Is it possible to do an overlay on top of another video signal?
    edited 2006-04-01 - 18:22:06
    I think you would need a sync detect circuit on the incoming video and use that to trigger the tv.spin object; some sort of signal mixing would be required as well.
    Jon Williams
  • Kaos KiddKaos Kidd Posts: 614
    edited 2006-04-03 - 14:28:10
    What about overlaying two Spin.TV outputs?
    Just tossing my two bits worth into the bit bucket
    KK
    edited 2006-04-03 - 14:31:57
    You could have two cogs writing to the same RAM buffer and then one TV object handling the rest. The frame buffer address would need to be known to any cog that wants to write to it.
    Jon Williams
    Post Edited (Jon Williams (Parallax)) : 4/3/2006 3:15:24 PM GMT
    Thanks Jon!
    I though it would be something along thoes lines, but I wasn't sure.
    KK
