Roaming with Photoresistors and Whiskers
Here is a routine I wrote. Would like to share it to everyone!
Jim
' Robotics with the Boe-Bot - RoamToLightWithWhiskers.bs2
' Boe-Bot uses elements from RoamtoLight and Whisker Navigation
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "START PROGRAM",CR
timeleft VAR Word
timeright VAR Word
average VAR Word
difference VAR Word
pulsecount VAR Byte
FREQOUT 4, 500,4000
GOSUB forward
DO
··· GOSUB test_photoresistors
··· GOSUB average_and_difference
··· GOSUB navigate
LOOP
test_photoresistors:
HIGH 6
PAUSE 3
RCTIME 6,1,timeleft
HIGH 3
PAUSE 3
RCTIME 3,1,timeright
DEBUG HOME, "timeright =· ", DEC5 timeright· ," timeleft =· ", DEC5 timeleft
RETURN
average_and_difference:
average = timeright + timeleft / 2
difference = average / 6
RETURN
navigate:
DEBUG HOME, "NAVIGATE", CR
··· IF (timeleft > timeright + difference) THEN
····· PULSOUT 13,850
····· PULSOUT 12,850
··· ELSEIF (timeright > timeleft + difference) THEN
····· PULSOUT 13,650
····· PULSOUT 12,650
··· ELSE
····· IF (IN5 = 0) AND (IN7 = 0) THEN
······· GOSUB back_up
······· GOSUB turn_left
····· ELSEIF (IN5 = 0) THEN
········ GOSUB back_up
········ GOSUB turn_right
····· ELSEIF (IN7 = 0) THEN
········ GOSUB turn_left
····· ELSE
········ GOSUB forward
····· ENDIF
··· ENDIF
··· PAUSE 10
RETURN
turn_left:
DEBUG HOME, "TURN LEFT", CR
FOR pulsecount = 0 TO 20
··· PULSOUT 13,650
··· PULSOUT 12,650
··· PAUSE 20
NEXT
RETURN
turn_right:
DEBUG HOME, "TURN RIGHT", CR
··· PULSOUT 13,850
··· PULSOUT 12,850
··· PAUSE 20
NEXT
RETURN
back_up:
DEBUG HOME,· "BACK UP", CR
FOR pulsecount = 0 TO 40
··· PULSOUT 13,650
··· PULSOUT 12,850
··· PAUSE 20
NEXT
RETURN
forward:
DEBUG HOME, "FORWARD", CR
PULSOUT 13,850
PULSOUT 12,650
PAUSE 20
RETURN
Jim
' {$STAMP BS2}
' {$PBASIC 2.5}
timeleft VAR Word
timeright VAR Word
average VAR Word
difference VAR Word
pulsecount VAR Byte
FREQOUT 4, 500,4000
GOSUB forward
DO
··· GOSUB navigate
LOOP
HIGH 6
PAUSE 3
RCTIME 6,1,timeleft
HIGH 3
PAUSE 3
RETURN
RETURN
navigate:
··· ELSE
····· ELSE
····· ENDIF
··· ENDIF
··· PAUSE 10
RETURN
turn_left:
··· PULSOUT 13,650
··· PULSOUT 12,650
··· PAUSE 20
NEXT
RETURN
turn_right:
··· PULSOUT 13,850
··· PULSOUT 12,850
··· PAUSE 20
NEXT
RETURN
back_up:
··· PULSOUT 13,650
··· PULSOUT 12,850
··· PAUSE 20
NEXT
RETURN
forward:
PULSOUT 13,850
PULSOUT 12,650
PAUSE 20
RETURN
thanks for sharing
Jim
