What else besides the chip?
With pre-order of chips only hours away, I'm wondering if there will be (or have I missed) any schematics/guides that will allow us to get a chip and start using it while we wait for the propeller development and demo boards to become available?
I know that there have been allusions that a home grown propeller clip would be easy to do, but haven't seen a schematic or other required support circuitry.
I'm guessing it's been posted and I missed it.
John R.
8 + 8 = 10
John R.
8 + 8 = 10
6+6=10 (Long live the duodecimal system!)
Oh and connect the Vdd and Vss on the right hand side of the chip as well (these are not shown as connected in the pdf, probably for clarity purposes), and as stated in the previous post, the EEPROM is optional.
Post Edited (Paul Baker) : 3/31/2006 11:12:22 PM GMT
I've provided the drawings below. Keep in mind there are variations (internal v. external clock/crystal; run from RAM, use an EEPROM for code). Since you'll have access to the P8X32AD-40 before the entire Starter Kit is ready, you'll need to get familiar with these connections.
Also, a word for the wise. Unless you want to deal with the serial port connection shown below, order your USB2SER from us right away. Once we start shipping Propellers we'll be out of USB2SERs and in a backorder situation on that product for a long time. Just buy it today while it is in stock and save yourself a future headache.
Would it be possible to clarify what is to be·included in the Propeller·Development Kit?· I might have overlooked this discussion elsewhere, but a quick search did not find it.
Daniel
Sure:
Propeller Demo Board (built-in Propeller)
USB cable
Propeller Manual
But keep in mind the kit might take a while after the chips are released. This part is so easy to use with a USB2SER I'd not get too caught up in waiting for the Starter Kit.
Ken,
What's the chances of Parallax building the serial adapter for the Propeller like ya'll have done for the BS1. After looking at the schematic for the BS1 serial adapter, it looks to me that making one for the Propeller should be a simple and cheap solution.
BS1 Serial Adapter Schematic
"OEM NMEA GPS Module" Now available on ebay for only $17.49
http://www.allsurplus.net/Axiom/
Post Edited (Mike Cook) : 4/1/2006 5:19:07 AM GMT
No plans for that yet, but it is a possibility. It depends on whether or not you'd like to have a Professional Development Board for Propeller, a through-hole Propeller Proto Board, 3.3V sensors (Ping, Memsic, etc.) and other related products first.
Ken,
Might be a chance for some of the 'smart guys' on this forum to make some cash by producing these as a cheap alternative to the USB adapter.
Any info on what type of crystal is needed for the Propeller?
Load Capacitance: specified or series?
I've found these at www.mouser.com:
20pF································ Series
Thanks Again,
Thanks for the info, and the heads up on the USB2SER.
I am assuming that the only way to use the current Pro Dev Board would be to mount the Propellor on the bread board, and use the USB2SER (or home grown serial connection) and build up everything else required on the bread board.
Am I also correct in thinking that we'd need an additional resistor inline with any of the input push butons, etc. to drop things down to 3.3 volts? Are we better off staying away from using the ancilliary devices on the PDB (and just using the bread board)?
Or is all this a mute point, and while we can "pre-order" the chips, by the time they ship will the demo and development boards be available?
John R.
8 + 8 = 10
PS - This looks like a fantastic device for a project I have underway using the javelin.
If you poke your nose around some of the threads started by Jon Williams, and download his Nuts and Volts articles availible for download from the Propeller webpage, you will get an idea of the look and feel of the IDE.
6+6=10 (Long live the duodecimal system)
Thx
