Power of the Sumobot — Parallax Forums
CaipiCaipi Posts: 11
edited 2006-03-28 22:49 in Robotics
Hello,
Is there a way to give my sumobot more power than he has now? During some tests, my sumobot was not strong enough to push another robot.
Of course, I firts should try with fresh batteries. But I want to give the motors an extra boost.
And idea that I have is to connect it to a 9V source. Does the print support this? Or do I need to connect only the motors to a higher volt source?
thx
  • A.C. fishingA.C. fishing Posts: 262
    edited 2006-03-28 20:21
    With Sumo-Bots, the angle is key. The angle which the bot hits the other bot is important to knocking it over.
    I don't think using a 9-volt battery will help at all. It might burn out some of your parts.
    edited 2006-03-28 20:25
    9 volt batteries will significantly reduce the life of the servos.· If it's a 9 volt transistor battery it wouldn't even have enough current capability to be worth doing that.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • CatharsisCatharsis Posts: 27
    Replace the servos with more powerful high performance versions.
