I have a program I would like to show, but I don't know how to attach it.· It's saved under bs2, and I can't find it on the browse key.· Thanks in advance to anyone that can help me.····· -SciTech02.
You need to know where on your computer the file is saved.· Using the attachment manager you should be able to navigate to the folder it is saved in and then select it and then upload.· Once it says the file has been uploaded you can close the window and submit your message.· If you can't find the file on your own computer you may need to try searching for it first.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
Chris Savage
