RoHS Compliance testing. Where ? How Much ?
Bean
Has anyone had any RoHS compliance testing done ?
Just wondering who does it, and how much they charge.
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Coming soon... Cheap 4-digit LED display with driver IC·www.hc4led.com
"Sometimes it is better to remain silent and be thought a fool, than to speak and remove all doubt."
Bean.
Please correct me if I'm wrong, but I thought that for RoHS manufacturing, there was no testing required; one "simply" has to use compliant components and a compliant soldering process.
This is what I was planning (now need) to do....... can anyone confirm or correct this?
Cheers,
Peter (pjv)
I have been given all kinds of differing info on the subject.
Some even say that you CAN use non-complient parts as long as the amount of offending substance is below the threshold for the TOTAL weight of the assembly.
I would rather be "safe than sorry" if the testing is not too expensive.
Bean.
It appears this product will get you started with DIY checking to assure you are not contaminated in the change over.
Frankly, it really looks, feels, and smells like a costly trade barrier. [noparse][[/noparse]like no genetically modified food stuffs]
Google shows a lot of big players ready to 'help out'.
Thomasnet may be your best resource to locate many services in your North American area.
It is nice to get a grip on heavy metal polution, but batteries really remain as a primary and indespensible source.
Since it is an export issue, the American Chamber of Commerce may be putting out info. The Small Business Administration is always a good neutral place for advice on how to proceed and profit.
It may be very simple inside Europe as it is a 'lead-free' zone.· Just use what you got.
It's more complicated than that. Some of the chemicals not allowed by RoHS are typically used as a flame retardent in printed circuit board laminate. Since reflow soldering of no-lead solder occurs at a higher temperature, the printed circuit board laminate has to be changed to handle the higher temperatures. Lead is frequently used in glass and fuses - so they need to be ROHS compliant also.
